259-106_ALT_0
259-106_ALT_1
Flow Max 12 VDC Fan 2410PL-04W-B30 0.12A 60mm x 25mm
Brand:|Model: 2410PL-04W-B30 07|Part # 259-106
60 mm sq. x 25 mm thick 12V DC brushless axial fan. * Rated voltage: 12 VDC * Rated current: 0.12 A * Rated input: 1.44 W
Part # 259-106
  • Perfect for computer case or amplifier cooling
  • Frame dimensions: 60 mm x 60 mm x 25 mm
  • 5-blade plastic impeller and frame
  • 8" long lead wires
60 mm sq. x 25 mm thick 12V DC brushless axial fan. 8" color coded wire leads with non-standard connector, red wire positive (+), black wire negative (-); simply cutoff connector for custom wiring. NMB-Minebea Flow Max # 2410PL-04W-B30 07. Made in Japan. Factory buyout—limited availability!
Specifications: • Rated voltage: 12 VDC • Rated current: 0.12 A • Rated input: 1.44 W • Dimensions: 60 mm x 60 mm x 25 mm.
  • Operating Voltage12 VDC
  • Size60 mm
  • BrandFactory Buyouts
  • Model2410PL-04W-B30 07
  • Part Number259-106
  • UPC844632099199
  • Product CategoryProducts
  • Weight0.15 lbs.
View similar products to the Flow Max 12 VDC Fan 2410PL-04W-B30 0.12A 60mm x 25mm
in the Products product category.
