245-302_ALT_0
245-302_ALT_1
245-302_ALT_4
Floor Box with Dual XLR & 1/4" Black 5" x 5"
Floor box provides an attractive, convenient, and durable means of temporarily connecting mic, line, or speaker cables.
  • Attractive and durable way to conceal connections
  • Brass and steel construction
  • Durable black enamel finish
  • Connector plate is removable for easy installation
  • Ideal for theaters, schools, and houses of worship
245-302
Weight: 1.76 lbs.
IN STOCK
List Price$54.99
You Save23%
$42.12
Buy 4-up$38.29
Part # 245-302
Floor boxes provide an attractive, convenient, and durable means of temporarily connecting mic, line, or speaker cables. Although built to withstand the wear and abuse of floor mounting, they may also be wall mounted whenever that application requires a sleek, stealthy appearance. The beveled faceplates are cast in solid brass, and the other metal parts and fittings are painted or plated, which ensures long-term protection against occasional exposure to moderate moisture. The Floor Box features two female XLR and two female 1/4" connectors mounted in a handy spring-loaded pop-up lid. The boxes are intelligently designed and carefully constructed to provide years of exceptional service, and will accept standard knockout cable fittings.
Features:  • Floor Box mounting space requirements: 4" square x 2.25" deep Faceplate dimensions: 4.75" square • Faceplate finish: Black enamel • Connectors: 2 x XLR female, and 2 x 1/4" TRS female • Removable mounting plate dimensions: 2-1/8" x 2-7/8".
  • BrandParts Express
  • Part Number245-302
  • UPC844632009143
  • Product CategoryFloor / Stage Boxes
    (2 Reviews)
  • Weight1.76 lbs.
View similar products to the Floor Box with Dual XLR & 1/4" Black 5" x 5"
in the Floor / Stage Boxes product category.
Floor Box with Dual XLR & 1/4" Black 5" x 5" is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from Perfect for Behringer P16-M MixersThis is the only pop up floor box I could find under $90 where I could remove the XLR jacks, replace them with RJ45 jacks and use them with the P16-M which needs Left and Right Audio Output and Ultranet In/Out. Bingo. Done!
Date published: 2013-10-10
Rated 3 out of 5 by from floor box reviewThis floor box looks nice in my stage. The biggest issue with it is in the way the xlr and 1 1/4 inch are fitted in it. They make it near impossible to get in and out to solder wire onto them. There are other boxes out there with easier accessible solder points.Overall the box looks nice but was a pain to get wire soldered onto it.
Date published: 2012-03-19
Is this weatherproof? I'm looking for floor boxes for an outdoor stage.
Asked by: jt57
Unfortunately this is not specifically weatherproof or weather resistant.
Date published: 2014-08-29
Is this offered in an NL4 version instead of 2 XLR's
Asked by: DGTsound
Unfortunately we do not.
Date published: 2014-04-29
how protect magnetic field
with low input mic unbalanced, how to protect againsthum or others ???
Asked by: halan
i'm not certain anything can be done to help an unbalanced mic, fairly vulnerable without common mode rejection....other than that, the enclosure of this unit should provide adequate shielding...of course a study of ground loops and how to track them down and eliminate them should solve the lions share of any such problems.
Answered by: rulgert
Date published: 2012-03-13
How to mount to floor
Any recommendations on how to mount the 4-inch electrical box to the floor when there are no mounting ears? I am in a locality that does not require conduit wiring - especially for simply microphone cable.
Asked by: HMTJ6821
mount box like a wall box ,from inside then install the cables and bolt the connection housing in pro type!
Answered by: digitalhaven 53
Date published: 2012-03-11
Customer projects that include: Floor Box with Dual XLR & 1/4" Black 5" x 5"
