Flat Metal Grill Pair
Flat Metal Grill Pair with 8mm Round Holes - 22" x 30"
This 22" x 30" flat metal grill has an 8 mm hole pattern, and comes packaged as a pair. Our flat metal grills protect your speakers with the same style and strength as the grills on expensive pro PA cabinets.
  • Grill measures 22" x 30" - 8 mm round holes
  • Powder coated 1.2 mm steel—professional strength!
  • Also available with 1" formed edges
  • Sold in pairs
262-888
Weight: 12.8 lbs.
IN STOCK
List Price$79.99
You Save25%
$59.59
Buy 4-up$54.18
Part # 262-888
Qty:  PR
This 22" x 30" flat metal grill has an 8 mm hole pattern, and comes packaged as a pair. Our flat metal grills protect your speakers with the same style and strength as the grills on expensive pro PA cabinets. This line of grills is constructed of black powder coated 1.2 mm steel, and is designed and sized to fit many pro audio speakers, or cut to fit large format custom speakers of all kinds.
  • BrandParts Express
  • Part Number262-888
  • UPC844632057373
  • Product CategorySteel Speaker Grills
  • Unit of MeasurePR
    (5 Reviews)
  • Weight12.8 lbs.
View similar products to the Flat Metal Grill Pair with 8mm Round Holes - 22" x 30"
in the Steel Speaker Grills product category.
Flat Metal Grill Pair with 8mm Round Holes - 22" x 30" is rated 3.8 out of 5 by 5.
Rated 4 out of 5 by from A fix to the vibration.If you're putting these on a bass cab or mains that are pumping out a lot of bass, I suggest mounting them with a curve or bow in it to stiffen it up. I got the idea from my mains and I'm going to apply the same thing to my bass cabs.
Date published: 2012-03-18
Rated 4 out of 5 by from DARN GOOD for the price.Mine were only a little bent at one corner. Of course I'd'a sent em back in a heartbeat if it was as bad as a lot of members have posted here. It probably depends on the discipline level at you're local fedex ground hub. The metal could be a lil thicker but before PE carried this I was to pay DOUBLE for grills or TRIPPLE for grills with the powder coating. Nit recommended for you're pro touring rig but it keeps the teenie-boppers off my cones.Looks pretty pro too with the black speaker fabric spray glued on back.I'd buy again.
Date published: 2010-08-19
Rated 5 out of 5 by from Great stuff - looks greatI used this stuff to build grilles for my Home Theatre (keep the cats away!). It worked perfect. Nice looking product as well. The only problem that I had with it was that it got damaged in shipping. One of the pieces had a huge dent in it. All of the pieces had the corners smashed up. I straightened it out and was able to repaint and use it again, but I was not happy with the way it was shipped.
Date published: 2009-01-19
Rated 5 out of 5 by from packagingrevise packaging as every piece ;damage on cornerssuggest leave a hard edge packing packing at corners ,
Date published: 2008-10-17
Rated 1 out of 5 by from Not for bass cabs.Used this grill on a 16x28 2-12 bass cab screwed every 6 to 8 inches with spray on rubber coating on the inside surface and it still rattles. Would not recommend
Date published: 2008-05-17
What is the percentage of open area?
Asked by: hifibob1
There is no information from the manufacture regarding this, however after a quick calculation roughly 90-95% of the grill is open area.
Date published: 2013-03-27
What are the Model #'s for the FLAT as opposed to the formed grills
Thanks for the response, the 12" x 18" would be perfect.... looking for the flat grills though
Asked by: DMSLV
the flat grills are only available in one size.
Answered by: Chrisf
Date published: 2013-01-31
Any smaller sizes available?
If I'm reading right, it says there are 4 versions... I don't need a pair that large
Asked by: DMSLV
There are three other sizes with this size opening. There is an 18 x 28 inch which is part number #262-884, A 15 x 22 inch that is #262-882, and a 12 x 18 inch that is #262-880
Answered by: Chrisf
Date published: 2013-01-30
Cutting
I'm about to order this Item and I was wondering what's the best way to cut this to size? I was thinking tin snips, but I'm afraid of getting warped edges. I could use a Dremel with a cutting blade, but that might be a little time consuming.
Asked by: Dizz E
A dremel-type cutter, or a pneumatic handheld cutting disc will work great. Or a steel shear machine.
Answered by: C from Claypool
Date published: 2012-03-19
Customer projects that include: Flat Metal Grill Pair with 8mm Round Holes - 22" x 30"
