Flat Metal Grill Pair with 6mm Round Holes - 22" x 30"
This 22" x 30" flat metal grill has a 6 mm hole pattern, and comes packaged as a pair. Our flat metal grills protect your speakers with the same style and strength as the grills on expensive pro PA cabinets.
  • Grill measures 22" x 30" - 6 mm round holes
  • Powder coated 1.2 mm steel—professional strength!
  • Also available with 1" formed edges
  • Sold in pairs
262-878
Weight: 12.8 lbs.
IN STOCK
List Price$77.99
You Save23%
$59.81
Buy 4-up$54.38
Part # 262-878
Qty:  PR
This 22" x 30" flat metal grill has a 6 mm hole pattern, and comes packaged as a pair. Our flat metal grills protect your speakers with the same style and strength as the grills on expensive pro PA cabinets. This line of grills is constructed of black powder coated 1.2 mm steel, and is designed and sized to fit many pro audio speakers, or cut to fit large format custom speakers of all kinds.
  • BrandParts Express
  • Part Number262-878
  • UPC844632057328
  • Product CategorySteel Speaker Grills
  • Unit of MeasurePR
    (16 Reviews)
  • Weight12.8 lbs.
View similar products to the Flat Metal Grill Pair with 6mm Round Holes - 22" x 30"
in the Steel Speaker Grills product category.
Flat Metal Grill Pair with 6mm Round Holes - 22" x 30" is rated 4.1875 out of 5 by 16.
Rated 5 out of 5 by from flat metal speaker grillI got this grill for new speakers cabinets it work just fine and look great very pro..I like it.
Date published: 2013-08-07
Rated 5 out of 5 by from good stuff!an excellent product!...used it in a pair of wedge cab floor monitors...plenty durable & really adds that professional detail to your work...note: there is a front & a back.
Date published: 2010-10-05
Rated 5 out of 5 by from Good productI use these grills (flat & formed) on all our Pro Audio builds now. Saves time, $ and looks great. Much better than going to the metal shop for custom pieces that cost more still have to be powder coated. They hold up on the road too.
Date published: 2010-08-16
Rated 4 out of 5 by from DITTO...BENT and then someFirst of all, these grills are made in the non-standard format of 1.2 mm thickness.Most all commercial grilles are a full 2mm thick. Grills are THINNER material to begin with.So follows, THINNER powder coating, which is not as lustrous as other grilles of this type. The packaging of the grilles leaves much to be desired (as stated in other reviews). The REAL issue with the packaging is:they are packaged BACKWARDS! Grill material is placed on either sides of a 1 Styrofoam block (sheet). This method leaves the grilles unprotected against the outer cardboard box that they are shipped in. This packing may be the issue of the maker of the grill, and not the fault of PARTS EXPRESS.Usually PARTS EXPRESS packaging methods of their other produces are EXCELLENT! All in all, I give the product 4 stars because of the ease of availability and economical cost.
Date published: 2010-02-01
Rated 5 out of 5 by from Good Grill stock makes custom speakers look betterwas easy to minupulate works great on cabintes i make, gives them that store bought look people want. cp - pro cabinet fabricator
Date published: 2009-09-07
Rated 3 out of 5 by from BentMine came with two bad corner bends and a baseball size shallow dent slightly off center, when I tried to bend it out, the powder coat flaked off. PE, please package these more carefully.
Date published: 2009-01-06
What's the best way to cut them. Grinder or table saw.
Asked by:
Do yo get 2 22x30 sheets?
Asked by: bknabe
Yes this is for a pair of grills that measure 22" x 30".
Date published: 2013-05-02
Customer projects that include: Flat Metal Grill Pair with 6mm Round Holes - 22" x 30"
