FiiO X5 Portable High Resolution Music Player for Lossless Music Formats 192k/24-bit
Brand:|Model: X5|Part # 230-142
Listen to your music for the first time, all over again. The X5 lossless DAP/DAC will amaze you with incredible instrument separation, a clearer soundstage, and a musical transparency that makes you feel like your favorite artists are in the room with you. So many features are packed into the sturdy CNC aluminum unibody enclosure. The X5 a more than a DAP; when connected to any computer it can be used as a DAC.
Comparable Items In Stock:
Part # 230-142
  • DAP/DAC supports DSD, APE, FLAC, ALAC, WAV, WMA, AAC, OGG, MP3
  • Utilizes 4760B dual-core processor for stellar audio performance
  • Dual micro SD ports - store up to 256 GB (not included)
  • Battery lasts 12 - 15 hours, recharges via USB
  • 10-band graphic equalizer helps dial in the perfect sound
  • Headphone, line, and coaxial outputs
  • Asynchronous USB DAC function
High Power Processors
Utilizing the Ingenics 4760B dual-core 600 MHz CPU, the FiiO X5 easily supports all six major lossless file types. Supported files are DSD, APE, FLAC, ALAC, WMA, and WAV. This Hi-Fi DAP has dual micro-SD inputs allowing for up to 128 GB of storage. Plug your X5 into any PC or Mac and it becomes a DAC instantly. With the onboard PCM1792 chip from Texas Instruments, expect a truly dynamic performance, supporting speeds of 192K/24B.
Amp and Equalizer
The built-in headphone amplifier is driven by dual Texas Instruments LMH6643 chips. These low distortion high efficiency amplifiers provide crystal clear sound to 16 ohm - 300 ohm headphones. Fine tune your sound with the built in graphic equalizer. Select between factory presets or move the sliders to dial in your custom sound. Play your lossless treasures for 12-15 hours on a single battery charge. The lithium-polymer battery will reach a full charge in just 4 hours when connected to the micro USB cable.
User Interface and Connectivity
FiiO makes sure you are always connected, with an all-mechanical scroll wheel and shortcut keys. The interface has been crafted via years of experience designing and building portable listening devices. Frequent firmware updates are yet another example of FiiO's commitment to continuous improvement. The X5 gives quick access to songs and the ability to batch songs instantly. The asynchronous USB DAC makes it easier than ever to load songs to your FiiO X5.
Included in the Box
Fiio X5 DAP/DAC • 1 m micro USB cable • Black semi-transparent silicone case • coaxial converting cable • OTG cable • User manual
Storage capacity: 2 micro SD card slots, up to 128G (micro SD not included) • Battery: 3700 mAH 3.7V lithium polymer battery • Screen: 2.4" HD IPS 400 x 360 resolution • Input/Output: 3.5 mm headphone out, 3.5 mm line out, 3.5 mm digital coaxial out, micro USB input • Supported files: DSD, APE, FLAC, ALAC, WAV, WMA, AAC, OGG, MP3 • CPU chip: JZ4760 • DAC chip: PCM1792 • AMP chips: LMH6643 • Frequency response: 20Hz - 20 KHz • Dimensions: 4.5" H x 2.66 W x 0.61" D.
Get the latest firmware update
  • BrandFiiO
  • ModelX5
  • Part Number230-142
  • Product CategoryPortable Media Players
    (5 Reviews)
  • Weight1.1030 lbs.
View similar products to the FiiO X5 Portable High Resolution Music Player for Lossless Music Formats 192k/24-bit
in the Portable Media Players product category.
