FiiO Mont Blanc E12 Portable Headphone Amp
Brand:|Model: E12|Part # 230-136
If you've been on the fence about buying a headphone amplifier, the FiiO E12 may be too good of a deal to pass up: a reasonably-priced, audiophile-grade headphone amp as much at home on the desktop as it is in your pocket.
List Price$129.00
Regular Price$129.00
You Save24%
Sale Price
Part # 230-136
  • FiiO brings out the best in your headphones
  • Long-life rechargeable lithium battery
  • Premium internal components selected for the highest fidelity
FiiO's new F12 headphone amplifier is a portable headphone amp with the power and specifications you'd expect to find on a bulky desktop amp. It follows FiiO's proven recipe for success, providing high-fidelity through superior design and parts selection, from the hefty brushed aluminum enclosure to the ALPS volume potentiometer and WIMA capacitors you'd find if you were to disassemble the E12.
Features are kept simple, with an emphasis on fidelity. There's an optional bass boost, specially designed to affect only bass frequencies, leaving mid-bass and midrange intact and unmodified. Gain is selectable between 0 dB and +16 dB. The "crossfeed" feature, when activated, sends some of the signal from each channel to the other. The effect is particularly well-implemented in the E12 and results in less listening fatigue and a focused soundstage, especially with older "hard pan" stereo recordings.
The internal lithium battery charges using any USB port and the included USB to USB Micro cable, giving over 12 hours of playback on a single charge.
A full complement of accessories rounds out this incredible package, including a USB to Micro USB cable for charging, a 3.5mm male to male cable for connecting a cell phone or MP3 player, robust rubber bands to strap the E12 to your portable device, and a velour carrying pouch.
Specifications: • Output power: ≥880 mW (32 Ω) • Supported impedance: 16~300 Ω • Signal-to-noise ratio: ≥ 110 dB (A-weighted, AUX input) • THD: <0.005% (AUX input) • Frequency response: 10-20,000 Hz • Signal to noise ratio: >110 dB • Gain: >16 dB (high setting) • Channel imbalance: <0.5 dB• Battery Capacity: 9.7 Wh (880 mAh/11.1V) • Battery life: >12 hours • Charging time <2.5 hours • Dimensions: 4.88" L x 2.58" W x 0.57" H (124 x 65.5 x 14.5 mm).
  • BrandFiiO
  • ModelE12
  • Part Number230-136
  • UPC6953175711216
  • Product CategoryHeadphone Amplifiers
    (3 Reviews)
  • Weight0.772 lbs.
View similar products to the FiiO Mont Blanc E12 Portable Headphone Amp
in the Headphone Amplifiers product category.
