FiiO D07 TV Digital Analog Converter
Brand:|Model: D07|Part # 230-134
Calamity! Your new TV only has digital audio outputs, but the sound system you'd like to connect has only analog inputs. The solution? FiiO's D07 digital audio converter, creating a stereo analog signal from nearly any digital format.
  • High quality metal case and sturdy construction quality for years of service
  • Ideal for connecting HDTV with legacy analog stereo equipment
  • Compatible with PCM stereo and all popular multi-channel formats
  • Accepts digital coaxial or toslink optical input up to 24-bit/96 kHz
  • Provides stereo 3.5mm stereo or left and right RCA line-level audio output
Device obsolescence is a peril of the digital age. Your old stereo may still sounds great, even without any digital features, but try to connect many modern TVs, and you may hit a wall. Many TV manufacturers are omitting analog audio outputs, leaving owners of legacy analog sound equipment in the lurch.
FiiO's D07 digital analog converter removes the need for an expensive stereo upgrade by translating nearly any digital audio format, including 5.1 and 7.1, from your TV's optical SPDIF or coaxial digital outputs into ol' fashioned analog stereo audio via 3.5mm or left/right RCA outputs.
The converter is powered by a mini-USB port, and the included mini-USB to USB cable can be used to connect to your TV's USB power port or the included AC adapter.
Advanced components in the D07 ensure compatibility with virtually any HDTV!
Specifications: • Supported sampling rates: up to 24-bit / 96 KHz • Signal to noise ratio: ≥90 dB • Stereo separation: ≥80 dB • Analog audio output level: 2V (0 dB Fs) • THD: <0.007% • Frequency response: 20-20,000 Hz • Dimension: 3-1/8" L x 1-7/8" W x 3/4" H.
  • BrandFiiO
  • ModelD07
  • Part Number230-134
  • UPC6953175750710
  • Product CategoryDigital Audio/Video Converters
    (2 Reviews)
  • Weight0.404 lbs.
View similar products to the FiiO D07 TV Digital Analog Converter
in the Digital Audio/Video Converters product category.
