Ferrofluid 100uL General Purpose for 1" Diameter V.C.
Brand:|Part # 340-540
Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling.
List Price$5.99
You Save35%
$3.90
Buy 4+$3.71
Part # 340-540
  • Great for retrofit/replacement or new applications
  • Damps impedance at resonance
  • Reduces distortion
  • Conducts heat away from voice coil
  • Increases power handling capacity
  • Comes complete with cleaning strips and instructions
  • Sized to fit approximate voice coil diameters
Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling. It should be used to replenish drivers treated previously with ferrofluid. With care, it can also upgrade most drivers that have never contained ferrofluid.
The kits listed are approximate fill quantities relative to approximate voice coil diameters. In general, the air gap should be 75% filled prior to inserting a voice coil diaphragm assembly. The kit contains synthetic ester-based ferrofluids and in most cases should not pose any adhesive incompatibility. It is recommended that this is confirmed by contacting the driver manufacturer prior to usage. Adding ferrofluid to a driver not intended for it will, in most cases, void the original manufacturer's warranty.
Included in kit: A ferrofluid packet, absorbent paper strips for removing old ferrofluid, detailed instructions, and material safety data sheet.
  • TypeFerrofluid
  • BrandFerrotec Corp USA
  • Part Number340-540
  • UPC844632086298
  • Product CategoryReplacement Diaphragms & Baskets
    (8 Reviews)
  • Weight0.1 lbs.
View similar products to the Ferrofluid 100uL General Purpose for 1" Diameter V.C.
in the Replacement Diaphragms & Baskets product category.
Ferrofluid 100uL General Purpose for 1" Diameter V.C. is rated 5.0 out of 5 by 8.
Rated 5 out of 5 by from Brings back the sparkleThe1 inch dome tweeters in my speakers are about 20 years old and ferrofluid cooled.After reading other positive reviews I bought these to replace the old fluid.Glad I did because it the old fluid was more like glue and most definitely restricting the tweeters.I changed the fluid and the results are great, I did one at a time to compare and wow, I have 6 more speakers to do and thenI'll be good for another 20 years of listening.
Date published: 2015-04-27
Rated 5 out of 5 by from works great!Bought thud product for our B & W speakers and brought the back to life!!
Date published: 2014-04-20
Rated 5 out of 5 by from Worked like a charmI replaced the dried up ferrofluid in my KEF 104.2 K-33 tweeters. The ferrofluid kits from Parts Express have just the right amount of fluid for one 1" tweeter. Ferrofluid is amazing stuff. It jumps right into the magnet gap. It really smoothed out the high frequencies on my KEFs. They sound brand new.
Date published: 2013-10-28
Rated 5 out of 5 by from Great Product...This fluid had a bit of a salty taste, but seasoned my chicken wonderfully… Oh wait, this was for my speaker. It seems to work great. I haven’t pushed the speakers yet, but I’m sure it will work great.
Rated 5 out of 5 by from saving tweeter lives :)Had to change my jbl tweeter diaphragms way too often n then realized I needed ferrofluid. Life savers and the best deal around.
Date published: 2013-08-18
Rated 5 out of 5 by from "Re-fill"I recently obtained a set of Metronome 7 speakers, they sounded terrible like the cones were frozen. A quick examination revealed the woofers and tweeters had fluid cooling that had dried i ordered 6 of these to refill my speakers after removing the old fluid. Amazing the difference. These speakers are now so good at doing nothing to the music. I close my eyes to point at the sound when i open them, I'm pointing no where near the speakers. Perfect! this replacement fluid was better than expected.
Date published: 2013-04-23
  • 2016-02-13T06:34CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_340-540, PRD, sort_mostRecent
Suitable for JBL 2412H-1 replacement?
My client removed all the ferro fluid in these JBL drivers (1" dia.) Is this a suitable replacement and is the amount correct for the driver cavity? Thanks.
Asked by: Mskee
Yes, it should do a fine job for you.
Answered by: RussR
Date published: 2011-09-19
  • 2016-02-13T07:19CST
  • loc_en_US, sid_340-540, PRD, sort_recentQuestionsFirst
