Fender 8" Full-Range Speaker 8 Ohm
Brand:|Part # 299-079
Save over 50% off the original retail price of this Fender 8" extended range speaker through this Parts Express exclusive factory buyout.
Part # 299-079
  • Vented 1-1/4" diameter aluminum voice coil former
  • Ribbed paper cone with cloth surround
  • Stamped steel frame with integrated mounting gasket
  • Originally developed for the $500 Fender Acoustasonic 150 guitar speaker
Fender designed the Acoustasonic guitar amplifier to deliver full, clear sound using this 8" extended range speaker. Not only does this driver play reasonably flat up to 7,000 Hz, the low free-air resonance, decent Xmax, and low Qts combine to produce great bass in sealed and ported speaker cabinets.
Save over 50% off, and up to 70% off, through this Parts Express exclusive factory buyout. Hurry, quantities are limited!
  • Nominal Diameter8"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response40 to 7,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter1.25"
  • Magnet Weight10 oz.
  • Resonant Frequency (Fs)41 Hz
  • DC Resistance (Re)5.47 ohms
  • Voice Coil Inductance (Le)2.01 mH
  • Mechanical Q (Qms)3.31
  • Electromagnetic Q (Qes)0.65
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)1.53 ft.³
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.312"
  • Baffle Cutout Diameter7.187"
  • Depth3"
  • Bolt Circle Diameter7.812"
  • # Mounting Holes4
  • Sealed Volume1.26 ft.³
  • Sealed F360 Hz
  • Vented Volume2.89 ft.³
  • Vented F330 Hz
  • BrandFactory Buyouts
  • Part Number299-079
  • UPC848864013008
  • Product CategoryWoofers
    (10 Reviews)
  • Weight2.4 lbs.
View similar products to the Fender 8" Full-Range Speaker 8 Ohm
