FaitalPRO WG101 Waveguide with HF100 1" Compression Driver
Brand:|Model: WG101|Part # 294-1043
Build your professional audio line array with FaitalPRO's WG101 waveguide. This package includes the unique HF100 compression driver from FaitalPro for frequency response up to 15,000 Hz.
Part # 294-1043
  • A unique line array waveguide packaged with a 1" horn driver
  • Two-piece design for easy mounting
  • 140° horizontal dispersion
FaitalPro created the purpose-built WG101 line array waveguide for maximum horizontal dispersion, while limiting the vertical off-axis output. This design allows for the use of stacked line array modules without comb filtering, or destructive interference.
The WG101 is designed for 1" two-bolt compression drivers, acoustically loading them down to 1,000 Hz. A 140° wide horizontal dispersion pattern offers superior off-axis response for the best available crowd coverage. For the best response, a 1,600 Hz crossover is recommended. For easy cabinet mounting, a two-piece design is used for inserting one side at a time. Once in place, the two pieces bolt together. Made in Italy.
WG101Specifications: • Throat diameter: 1" • Driver mounting: 2-bolt • Recommended minimum crossover point: 1,600 Hz • Overall dimensions: 4.81" H x 3.86" W x 4.33" D, Cutout: See Manuals/Resources for a cutout template.
This package includes the FaitalPRO HF100. It is a 1" compression horn driver that is built using a dome ketone polymer dome diaphragm for an impressively flat frequency response from 1,500 Hz to 18,000 Hz, without sacrificing sensitivity. A radial phase plug increases dispersion, improving off-axis response. Two-bolt mounting pattern with M6 threads. Made in Italy.
HF100 Specifications: • Power handling: 30 watts RMS with recommended crossover of 2,000 Hz, 12 dB/octave slope • VCdia: 0.98" • Impedance: 8 ohms • Frequency response: 1,500-20,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 3.58" diameter x 2.40" depth • Bolt pattern: 2 x M6 • Weight: 1.83 lbs.
FaitalPRO WG101 Waveguide with HF100 1" Compression Driver includes the following items:
Qty Part # Item
1294-1001FaitalPRO HF100 1" Compression Horn Driver 8 Ohm 2-Bolt
1999-1043FaitalPRO WG101 1" 140 degree W Coverage Waveguide 2-Bolt
  • Diaphragm MaterialPoly / Mylar
  • Impedance8 ohms
  • Power Handling (RMS)30 Watts
  • BrandFaitalPRO
  • ModelWG101
  • Part Number294-1043
  • UPC848864012407
  • Product CategoryHorn Loaded Tweeters & Midranges
  • Weight2.89 lbs.
View similar products to the FaitalPRO WG101 Waveguide with HF100 1" Compression Driver
in the Horn Loaded Tweeters & Midranges product category.
