FaitalPRO W8N8-150 8" Neodymium Professional Midbass 16 Ohm
Brand:|Model: W8N8-150|Part # 294-1173
For high fidelity applications, choose FaitalPRO's W8N8-150 8" professional woofer. Decent Xmax and high frequency extension are complimented by a lightweight motor design.
ORDER TODAY
Ships in 7-10 Business Days
$141.00
Part # 294-1173
  • Compact, cast aluminum frame for tight driver placement
  • Lightweight, high output neo motor
  • M-Roll surround and treated paper cone
  • 16 ohm impedance
  • 93 dB sensitivity and high 150 watt power handling
FaitalPRO's W8N8-150 8" professional woofer driver has an extremely flat response from 80 to 5,000 Hz for use in applications where high power handling and midbass punch is required, such as live sound speakers. The high energy, rare-earth neodymium motor keeps the driver lightweight.
A treated paper cone with a cloth M-Roll surround offers outstanding durability, while the cast aluminum octagonal frame allows for very tight speaker-to-speaker placement, which is ideal for multi-way speakers and line arrays. 16 ohm impedance for wiring in groups. Made in Italy.
  • Nominal Diameter8"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance16 ohms
  • Frequency Response80 to 6,300 Hz
  • Sensitivity93 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)76 Hz
  • DC Resistance (Re)11.8 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)19.5
  • Electromagnetic Q (Qes)0.88
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)0.39 ft.³
  • Mechanical Compliance of Suspension (Cms)0.18 mm/N
  • BL Product (BL)12.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)23.8g
  • Moving Mass Of Diaphragm (Mmd)22.8
  • Maximum Linear Excursion (Xmax)5.52 mm
  • Surface Area of Cone (Sd)206 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.27" across the flats, 8.81"
  • Baffle Cutout Diameter7.13"
  • Depth4.59"
  • Bolt Circle Diameter8.19"
  • # Mounting Holes8
  • Sealed Volume0.32 ft.³
  • Sealed F3112 Hz
  • Vented Volume0.73 ft.³
  • Vented F354 Hz
  • BrandFaitalPRO
  • ModelW8N8-150
  • Part Number294-1173
  • UPC848864010946
  • Weight3.96 lbs.
View similar products to the FaitalPRO W8N8-150 8" Neodymium Professional Midbass 16 Ohm
