FaitalPRO HF144 1.4" Neodymium Compression Horn Driver 16 Oh
FaitalPRO HF144 1.4" Neodymium Compression Horn Driver 16 Ohm 4-Bolt
Brand:|Model: HF144|Part # 294-1024
For a smooth sounding compression driver to be used for the critical midrange (vocals), choose FaitalPRO's HF144 1.4" compression driver. A radial neodymium slug motor focuses magnet flux into the gap while keeping driver weight below 5 pounds. 16 ohm impedance for line array use.
ORDER TODAY
Ships in 7-10 Business Days
$251.00
Part # 294-1024
  • Neo radial motor design for light weight and high output
  • Ketone polymer dome diaphragm for smooth output with a focus on vocals
  • Large voice coil for high power handling
  • Wide band 700 Hz to 18,000 Hz frequency response
  • 16 ohm impedance for line array use
  • Made in Italy
Frequently Bought Together
FailtalPRO's HF144 1.4" compression horn driver uses a radial neodymium slug motor design to pack as much BL product into the voice coil gap as possible. When combined with the ketone polymer dome diaphragm, the HF144 produces smooth, neutral sound over a broad range (from 700 to 18,000 Hz, similar to the HF146) with an emphasis on the critical midrange.
The high energy motor is also response for output up to 111 dB with only one watt of input power, with a 109 dB average sensitivity, while keeping the total weight of the driver under five pounds. Built with an annular phase plug. The 16 ohm impedance is great for line array use where multiple drivers are used together. Made in Italy.
Specifications: • Power handling: 40 watts RMS (above 650 Hz), 80 watts RMS (above 900 Hz) with recommended crossover of 900 Hz, 12 dB/octave slope  • VCdia: 2.56" • Impedance: 16 ohms • Frequency response: 700-18,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 4.84" diameter x 2.50" depth • Bolt pattern: 4 x M6 • Weight: 4.41 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter1.4"
  • Diaphragm MaterialPoly / Mylar
  • Impedance16 ohms
  • Power Handling (RMS)80 Watts
  • BrandFaitalPRO
  • ModelHF144
  • Part Number294-1024
  • UPC848864011431
  • Product CategoryHorn Drivers
  • Weight4.41 lbs.
View similar products to the FaitalPRO HF144 1.4" Neodymium Compression Horn Driver 16 Ohm 4-Bolt
in the Horn Drivers product category.
