FaitalPRO HF10AK 1" Neodymium Compression Horn Driver 16 Ohm 2/3-Bolt
Brand:|Model: HF10AK|Part # 294-1010
Choose the HF10AK 1" compression driver from FaitalPRO for upgrading your professional audio speaker cabinet. A 2/3-bolt pattern makes for easy attachment to most all 1" horns and waveguides, and a ketone polymer diaphragm creates smooth sound. 16 ohm impedance is great for line arrays.
ORDER TODAY
Ships in 7-10 Business Days
$212.00
Part # 294-1010
  • Ketone polymer dome diaphragm for smooth output from 1 kHz to 20 kHz
  • 16 ohm impedance for line array use
  • 2/3-bolt mounting pattern with M6 threads
  • Lightweight neodymium ring motor and 110 dB average sensitivity
  • Annular phase plug
  • Made in Italy
FaitalPRO's HF10AK 1" horn compression driver features a ketone polymer dome diaphragm for smooth sound that extends from 1,000 Hz up to 20,000 Hz. Built with an annular phase plug.
A high energy, lightweight neodymium motor helps the HF10AK to produce output up to 112 dB (1W/1m), with an overall average sensitivity of 110 dB. The 16 ohm impedance makes FaitalPRO's HF10AK a great choice for line arrays, where multiples are use together. For higher power handling, a larger 1.73" voice coil is used. Made in Italy.
Specifications: • Power handling: 60 watts RMS with recommended crossover of 1,300 Hz, 12 dB/octave slope • VCdia: 1.73" • Impedance: 8 ohms • Frequency response: 1,000-20,000 Hz • SPL: 110 dB 1W/1m • Dimensions: 4.02" diameter x 2.13" depth • Bolt pattern: 2/3 x M6 • Weight: 3.09 lbs.
  • Mounting Type2-Bolt/3-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialKapton / Polyimide
  • Impedance16 ohms
  • Power Handling (RMS)60 Watts
  • BrandFaitalPRO
  • ModelHF10AK
  • Part Number294-1010
  • UPC848864011295
  • Product CategoryHorn Drivers
  • Weight3.09 lbs.
View similar products to the FaitalPRO HF10AK 1" Neodymium Compression Horn Driver 16 Ohm 2/3-Bolt
in the Horn Drivers product category.
