FaitalPRO 8PR200 8" Neodymium Professional Midbass 16 Ohm
Brand:|Model: 8PR200|Part # 294-1176
For high fidelity applications, choose FaitalPRO's 8PR200 8" professional woofer. Good Xmax and high frequency extension are complimented by a lightweight motor design, while an aluminum demodulation ring reduces Le and distortion.
ORDER TODAY
Ships in 7-10 Business Days
$195.00
Part # 294-1176
  • Compact, cast aluminum frame for tight driver placement
  • Lightweight, high output neo motor with demodulation ring
  • Triple roll surround and treated paper cone
  • 95 dB sensitivity, 200 watt power handling, and 16 ohm impedance
FaitalPRO's 200 watt RMS 8PR200 8" professional woofer driver has an extremely flat response from 70 to 5,000 Hz for use in applications where high power handling and midbass punch is required, such as in live sound speakers. The high energy, rare-earth neodymium motor is lightweight and features an aluminum demodulation ring for low inductance and distortion.
A treated paper cone with a cloth triple roll surround offers outstanding durability, while the cast aluminum octagonal frame allows for very tight speaker-to-speaker placement, which is ideal for multi-way speakers and line arrays. 16 ohm impedance for multiple speaker grouping. Made in Italy.
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance16 ohms
  • Frequency Response70 to 5,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)65 Hz
  • DC Resistance (Re)11.8 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)10.75
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)0.45 ft.³
  • Mechanical Compliance of Suspension (Cms)0.23 mm/N
  • BL Product (BL)15 Tm
  • Diaphragm Mass Inc. Airload (Mms)25.5g
  • Moving Mass Of Diaphragm (Mmd)24
  • Maximum Linear Excursion (Xmax)8.65 mm
  • Surface Area of Cone (Sd)196 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.27" across the flats, 8.81"
  • Baffle Cutout Diameter7.13"
  • Depth4.59"
  • Bolt Circle Diameter8.19"
  • # Mounting Holes8
  • Sealed Volume0.32 ft.³
  • Sealed F3100 Hz
  • Vented Volume0.78 ft.³
  • Vented F348 Hz
  • BrandFaitalPRO
  • Model8PR200
  • Part Number294-1176
  • UPC848864008653
  • Weight4.63 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the FaitalPRO 8PR200 8" Neodymium Professional Midbass 16 Ohm
