FaitalPRO 8FE200 8" Professional Midbass 8 Ohm
Brand:|Model: 8FE200|Part # 294-1171
With a linear frequency response from 60 to 5,000 Hz and a high sensitivity of 95 dB, FaitalPRO's 8FE200 8" midrbass speaker stands out as a great value for professional, high output home audio, and car audio applications.
$48.00
Part # 294-1171
  • 130 watt RMS, 260 watt program power handling
  • Cloth triple roll surround
  • High power ferrite ring motor for 95 dB sensitivity
  • Made in Italy
FaitalPRO's 8FE200 8" professional midbass speaker is purpose-built to cover from 60 Hz to 5,000 Hz in three-way speakers, but also works great as a door speaker in car audio applications and a woofer in two-way speakers.
To ensure absolute signal fidelity, FaitalPRO built the 8FE200 with a strong ferrite ring-powered motor. Not only does this increase sensitivity to 95 dB (1W/1m), it keeps the Qts at a respectable figure of 0.63. A triple roll cloth surround, stamped steel frame, and treated paper cone combine to make the 8FE200 a truly durable driver. Made in Italy.
  • Nominal Diameter8"
  • Power Handling (RMS)130 Watts
  • Power Handling (max)260 Watts
  • Impedance8 ohms
  • Frequency Response60 to 5,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter1.46"
  • Resonant Frequency (Fs)80 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.44 mH
  • Mechanical Q (Qms)13
  • Electromagnetic Q (Qes)0.66
  • Total Q (Qts)0.63
  • Compliance Equivalent Volume (Vas)0.48 ft.³
  • Mechanical Compliance of Suspension (Cms)0.26 mm/N
  • BL Product (BL)8.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)15g
  • Moving Mass Of Diaphragm (Mmd)13.5
  • Maximum Linear Excursion (Xmax)4.67 mm
  • Surface Area of Cone (Sd)191 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.24"
  • Baffle Cutout Diameter6.93"
  • Depth3.5"
  • Bolt Circle Diameter7.75"
  • # Mounting Holes4
  • Sealed Volume0.76 ft.³
  • Sealed F3101 Hz
  • Vented Volume1.21 ft.³
  • Vented F352 Hz
  • BrandFaitalPRO
  • Model8FE200
  • Part Number294-1171
  • UPC848864010922
    (5 Reviews)
  • Weight5.2 lbs.
