FaitalPRO 8FE200 8" Professional Midbass 4 Ohm
Brand:|Model: 8FE200|Part # 294-1170
With a linear frequency response from 60 to 5,000 Hz and a high sensitivity of 95 dB, FaitalPRO's 8FE200 8" midrbass speaker stands out as a great value for professional, high output home audio, and car audio applications.
- Order Soon - Only 1 Left In StockMore Due In November 4, 2016
Part # 294-1170
  • High power ferrite ring motor for low Qts and sensitivity
  • 130 watt RMS, 260 watt program power handling
  • Cloth triple roll surround
  • Made in Italy
FaitalPRO's 8FE200 8" professional midbass speaker is purpose-built to cover from 60 Hz to 5,000 Hz in three-way speakers, but also works great as a door speaker in car audio applications.
To ensure absolute signal fidelity, FaitalPRO built the 8FE200 with a strong ferrite ring-powered motor. Not only does this increase sensitivity to 95 dB (1W/1m), it keeps the Qts at a respectable figure of 0.44. A triple roll cloth surround, stamped steel frame, and treated paper cone combine to make the 8FE200 a truly durable driver. Made in Italy.
  • Nominal Diameter8"
  • Power Handling (RMS)130 Watts
  • Power Handling (max)260 Watts
  • Impedance4 ohms
  • Frequency Response60 to 5,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter1.46"
  • Resonant Frequency (Fs)80 Hz
  • DC Resistance (Re)3 ohms
  • Voice Coil Inductance (Le)0.25 mH
  • Mechanical Q (Qms)8.7
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)0.47 ft.³
  • Mechanical Compliance of Suspension (Cms)0.26 mm/N
  • BL Product (BL)7 Tm
  • Diaphragm Mass Inc. Airload (Mms)15.3g
  • Moving Mass Of Diaphragm (Mmd)13.8
  • Maximum Linear Excursion (Xmax)4.62 mm
  • Surface Area of Cone (Sd)191 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.24"
  • Baffle Cutout Diameter6.93"
  • Depth3.5"
  • Bolt Circle Diameter7.75"
  • # Mounting Holes8
  • Sealed Volume0.2 ft.³
  • Sealed F3145 Hz
  • Vented Volume0.51 ft.³
  • Vented F374 Hz
  • BrandFaitalPRO
  • Model8FE200
  • Part Number294-1170
  • UPC848864010915
    (1 Reviews)
  • Weight5.1500 lbs.
View similar products to the FaitalPRO 8FE200 8" Professional Midbass 4 Ohm
