FaitalPRO 6FE200 6" Professional Midrange Speaker 8 Ohm
Brand:|Model: 6FE200|Part # 294-1152
With a linear frequency response from 100 to 5,000 Hz and a high sensitivity of 95 dB, FaitalPRO's 6FE200 6" midrange speaker stands out as a great value for professional, high output home audio, and car audio applications.
$44.00
Part # 294-1152
  • High power ferrite ring motor for low Qts and high sensitivity
  • 130 watt RMS, 260 watt program power handling
  • Cloth M-roll surround
  • Made in Italy
FaitalPRO's open back 6FE200 6" professional midrange speaker is purpose-built to cover the critical midrange in three-way speakers, but also works great as a door speaker in car audio applications. To ensure absolute signal fidelity, FaitalPRO built the 6FE200 with a strong ferrite ring-powered motor. Not only does this increase sensitivity, it keeps the Qts at a respectable figure of 0.67. Made in Italy.
  • Nominal Diameter6"
  • Power Handling (RMS)130 Watts
  • Power Handling (max)260 Watts
  • Impedance8 ohms
  • Frequency Response85 to 6,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter1.46"
  • Resonant Frequency (Fs)120 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.4 mH
  • Mechanical Q (Qms)6.23
  • Electromagnetic Q (Qes)0.75
  • Total Q (Qts)0.67
  • Compliance Equivalent Volume (Vas)0.11 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • Diaphragm Mass Inc. Airload (Mms)11.5g
  • Moving Mass Of Diaphragm (Mmd)11.06
  • Maximum Linear Excursion (Xmax)4.67 mm
  • Surface Area of Cone (Sd)118 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.59"
  • Baffle Cutout Diameter5.59"
  • Depth3.03"
  • Bolt Circle Diameter6.06"
  • # Mounting Holes4
  • Sealed Volume0.25 ft.³
  • Sealed F3143 Hz
  • Vented Volume0.31 ft.³
  • Vented F376 Hz
  • BrandFaitalPRO
  • Model6FE200
  • Part Number294-1152
  • UPC848864010984
    (2 Reviews)
  • Weight4.87 lbs.
View similar products to the FaitalPRO 6FE200 6" Professional Midrange Speaker 8 Ohm
