FaitalPRO 18XL1600 18" Neodymium Professional Subwoofer 8 Ohm
Brand:|Model: 18XL1600|Part # 294-1313
For a lightweight, high output 18" woofer with extended frequency response, choose FaitalPRO's neodymium-powered 18XL1600 subwoofer. Its 4" diameter voice coil offers up to 1,600 watts RMS power handling.
Part # 294-1313
  • 1,600 watt power handling and just 26.9 pounds
  • Low distortion motor with three aluminum shorting rings
  • Over 12 mm of Xmax for deep bass reproduction
  • Custom cast aluminum frame
  • Made in Italy
FaitalPRO's 18XL1600 18" professional subwoofer packs 1,600 watts of RMS power handling into a package that weighs less than 27 pounds, thanks to a neodymium motor and 4" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion.
For an extended frequency response and reduced distortion, the 18XL1600 employs three separate aluminum demodulation rings within the motor to reduce inductance down to a low 1.45 mH. 12.9 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned very low. Made in Italy.
  • Nominal Diameter18"
  • Power Handling (RMS)1,600 Watts
  • Power Handling (max)3200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 1,500 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)1.45 mH
  • Mechanical Q (Qms)9.3
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)6.52 ft.³
  • Mechanical Compliance of Suspension (Cms)0.1 mm/N
  • BL Product (BL)26.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)240g
  • Moving Mass Of Diaphragm (Mmd)217
  • Maximum Linear Excursion (Xmax)12.9 mm
  • Surface Area of Cone (Sd)1124 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.54"
  • Depth9.09"
  • Bolt Circle Diameter17.32"
  • # Mounting Holes8
  • Sealed Volume1.59 ft.³
  • Sealed F371 Hz
  • Vented Volume3.63 ft.³
  • Vented F341 Hz
  • BrandFaitalPRO
  • Model18XL1600
  • Part Number294-1313
  • UPC848864008035
  • Weight30.65 lbs.
View similar products to the FaitalPRO 18XL1600 18" Neodymium Professional Subwoofer 8 Ohm
