FaitalPRO 18HP1060 18" Neodymium Professional Subwoofer 8 Ohm
Brand:|Model: 18HP1060|Part # 294-1310
For a lightweight, high output subwoofer solution, choose FaitalPRO's neodymium-powered 18HP1060 18" subwoofer. Its 4" diameter voice coil offers up to 1,200 watts RMS power handling.
$490.00
Part # 294-1310
  • 1,200 watt power handling and just 16.09 pounds
  • Low distortion motor with an aluminum shorting ring
  • Over 12 mm of Xmax for deep bass reproduction
  • Custom cast aluminum frame
  • Made in Italy
FaitalPRO's 18HP1060 18" professional subwoofer packs 1,200 watts of RMS power handling into a package that weighs less than 16 pounds, thanks to a neodymium motor and 4" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion.
For an extended frequency response and reduced distortion, the 18HP1060 employs an aluminum demodulation ring on top of the pole piece to reduce inductance down to a low 1.26 mH. 12.45 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned very low. Made in Italy.
  • Nominal Diameter18"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2400 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,600 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.26 mH
  • Mechanical Q (Qms)11.1
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)6.18 ft.³
  • Mechanical Compliance of Suspension (Cms)0.09 mm/N
  • BL Product (BL)24.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)211.8g
  • Moving Mass Of Diaphragm (Mmd)189.1
  • Maximum Linear Excursion (Xmax)12.45 mm
  • Surface Area of Cone (Sd)1124 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.54"
  • Depth8.46"
  • Bolt Circle Diameter17.32"
  • # Mounting Holes8
  • Sealed Volume1.61 ft.³
  • Sealed F375 Hz
  • Vented Volume3.78 ft.³
  • Vented F343 Hz
  • BrandFaitalPRO
  • Model18HP1060
  • Part Number294-1310
  • UPC848864008066
    (2 Reviews)
  • Weight20.6 lbs.
View similar products to the FaitalPRO 18HP1060 18" Neodymium Professional Subwoofer 8 Ohm
