FaitalPRO 18HP1030 18" Professional Subwoofer 8 Ohm
Brand:|Model: 18HP1030|Part # 294-1307
For a high output subwoofer solution, choose FaitalPRO's 18HP1030 18" subwoofer. Its 4" diameter voice coil offers up to 1,200 watts RMS power handling, while the aluminum demodulation ring lowers distortion and inductance.
$415.00
Part # 294-1307
  • 1,200 watt RMS power handling
  • Low distortion motor with an aluminum demodulation ring
  • Over 12 mm of Xmax for deep bass reproduction
  • Custom cast aluminum frame
  • Made in Italy
FaitalPRO's 18HP1030 18" professional subwoofer features 1,200 watts of RMS power handling thanks to a 4" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion. The vented backplate lowers voice coil temperatures.
For an extended frequency response and reduced distortion, the 18HP1030 employs an aluminum demodulation ring on top of the pole piece to reduce inductance down to a low 1.48 mH. 12.45 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned very low. Made in Italy.
  • Nominal Diameter18"
  • Power Handling (RMS)1200 Watts
  • Power Handling (max)2400 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,600 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.48 mH
  • Mechanical Q (Qms)11.6
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)5.72 ft.³
  • Mechanical Compliance of Suspension (Cms)0.09 mm/N
  • BL Product (BL)24.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)228.6g
  • Moving Mass Of Diaphragm (Mmd)205.8
  • Maximum Linear Excursion (Xmax)12.45 mm
  • Surface Area of Cone (Sd)1124 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.5"
  • Depth8.21"
  • Bolt Circle Diameter17.32"
  • # Mounting Holes8
  • Sealed Volume1.95 ft.³
  • Sealed F368 Hz
  • Vented Volume4.94 ft.³
  • Vented F337 Hz
  • BrandFaitalPRO
  • Model18HP1030
  • Part Number294-1307
  • UPC848864008080
  • Weight30.05 lbs.
Pyle PBW10S 10" Midbass
Part #  292-2528
Pyle PBW8S 8" Midbass
Part #  292-2532
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
View similar products to the FaitalPRO 18HP1030 18" Professional Subwoofer 8 Ohm
