FaitalPRO 18FH510 18" Professional Subwoofer 4 Ohm
Brand:|Model: 18FH510|Part # 294-1301
For a high output subwoofer solution, choose FaitalPRO's 18FH510 18" subwoofer. A low Qts figure allows it to be used in 4 cubic foot ported enclosures and an EBP of 100 means it works well in horn loaded enclosures.
Ships in 7-10 Business Days
Part # 294-1301
  • High output with combined with great Xmax
  • Low inductance motor allows for extended frequency response
  • Robust cast aluminum basket
  • Great for use in ported and horn loaded enclosures
FaitalPRO's Five Hundred Series drivers are built to be highly reliable and versatile. The 18FH510 was developed for use in ported and horn loaded enclosures as a subwoofer. An extended frequency response that reaches to 2,000 Hz allows this 18" to be used in large multi-way speakers as a woofer.
A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion and the bumped backplate protects the voice coil former from bottoming out. Made in Italy.
  • Nominal Diameter18"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance4 ohms
  • Frequency Response30 to 2,500 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)3.3 ohms
  • Voice Coil Inductance (Le)1.06 mH
  • Mechanical Q (Qms)13.6
  • Electromagnetic Q (Qes)0.27
  • Total Q (Qts)0.26
  • Compliance Equivalent Volume (Vas)12.39 ft.³
  • Mechanical Compliance of Suspension (Cms)0.19 mm/N
  • BL Product (BL)18.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)146g
  • Moving Mass Of Diaphragm (Mmd)124
  • Maximum Linear Excursion (Xmax)9.25 mm
  • Surface Area of Cone (Sd)1134 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.57"
  • Depth7.93"
  • Bolt Circle Diameter17.32"
  • # Mounting Holes6
  • Sealed Volume1.41 ft.³
  • Sealed F392 Hz
  • Vented Volume2.74 ft.³
  • Vented F360 Hz
  • BrandFaitalPRO
  • Model18FH510
  • Part Number294-1301
  • UPC848864008141
  • Weight23.1000 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the FaitalPRO 18FH510 18" Professional Subwoofer 4 Ohm
