FaitalPRO 18FH500 18" Neodymium Professional Subwoofer 8 Ohm
Brand:|Model: 18FH500|Part # 294-1300
For a lightweight, high output subwoofer solution, choose FaitalPRO's neodymium-powered 18FH500 18" subwoofer.
$345.00
Part # 294-1300
  • Custom cast aluminum frame
  • Rare earth neodymium slug motor
  • Triple roll treated polycotton surround
  • Designed for vented and horn loaded enclosures
  • Made in Italy
FaitalPRO's Five Hundred Series drivers are built to be highly reliable and versatile. An extended frequency response that reaches to 3,000 Hz allows this 18" to be used in large multi-way speakers as a woofer.
A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion. The high power neodymium motor keeps sensitivity high while decreasing the weight of the driver. Made in Italy.
  • Nominal Diameter18"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 3,150 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.35 mH
  • Mechanical Q (Qms)12.5
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)12.23 ft.³
  • Mechanical Compliance of Suspension (Cms)0.21 mm/N
  • BL Product (BL)19 Tm
  • Diaphragm Mass Inc. Airload (Mms)137g
  • Moving Mass Of Diaphragm (Mmd)114.9
  • Maximum Linear Excursion (Xmax)9.25 mm
  • Surface Area of Cone (Sd)1134 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter18.11"
  • Baffle Cutout Diameter16.61"
  • Depth7.95"
  • Bolt Circle Diameter17.32"
  • # Mounting Holes8
  • Sealed Volume2.75 ft.³
  • Sealed F369 Hz
  • Vented Volume6.2 ft.³
  • Vented F341 Hz
  • BrandFaitalPRO
  • Model18FH500
  • Part Number294-1300
  • UPC848864008134
  • Weight13.75 lbs.
View similar products to the FaitalPRO 18FH500 18" Neodymium Professional Subwoofer 8 Ohm
