FaitalPRO 15HP1020 15" Neodymium Professional Woofer 8 Ohm
Brand:|Model: 15HP1020|Part # 294-1279
For a lightweight, high output woofer solution, choose FaitalPRO's neodymium-powered 15HP1020 15" woofer. Its 4" diameter voice coil offers up to 700 watts RMS power handling.
Regular Price$369.00
You Save22%
Sale Price
$288.00
Part # 294-1279
  • 700 watt power handling
  • 9 mm of Xmax for deep bass reproduction
  • Custom cast aluminum frame
  • Made in Italy
Frequently Bought Together
FaitalPRO's 15HP1020 15" professional woofer packs 700 watts of RMS power handling into a package that weighs less than 14 pounds, thanks to a neodymium motor and 4" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion.
The 15HP1020 mates well with most any 1", 1.4", or 2" compression horn driver, for a great sounding large format two-way speaker. 9 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned reasonably low. Made in Italy.
  • Nominal Diameter15"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)10.2
  • Electromagnetic Q (Qes)0.28
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)3.87 ft.³
  • Mechanical Compliance of Suspension (Cms)0.13 mm/N
  • BL Product (BL)24.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)118g
  • Moving Mass Of Diaphragm (Mmd)106.2
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)759 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.47"
  • Baffle Cutout Diameter13.94"
  • Depth7.14"
  • Bolt Circle Diameter14.72"
  • # Mounting Holes8
  • Sealed Volume0.48 ft.³
  • Sealed F3118 Hz
  • Vented Volume0.94 ft.³
  • Vented F375 Hz
  • BrandFaitalPRO
  • Model15HP1020
  • Part Number294-1279
  • UPC848864008219
  • Weight16.1 lbs.
View similar products to the FaitalPRO 15HP1020 15" Neodymium Professional Woofer 8 Ohm
