FaitalPRO 15FH520 15" Neodymium Professional Woofer 16 Ohm
Brand:|Model: 15FH520|Part # 294-1276
Choose the lightweight, neodymium-powered FaitalPRO 15FH520 15" woofer for high output woofer duties. Up to 600 watts RMS power handling is combined with a high, 97 dB sensitive (1W/1m) design.
Ships in 7-10 Business Days
Part # 294-1276
  • Extremely linear response up to 4,000 Hz
  • 3" aluminum voice coil and a lightweight, powerful neo slug motor
  • Distortion and inductance reducing aluminum demodulation ring
  • Open cast aluminum frame allows driver to move freely
  • Made in Italy
Frequently Bought Together
FaitalPRO's 15FH520 15" neodymium woofer is designed for maximum bass punch and clarity and clocks in at just over 10 pounds. An aluminum demodulation ring in the motor reduces inductance for a frequency response that extends up to 4,000 Hz, while reducing distortion. Its open cast aluminum basket makes this speaker structurally solid, while minimizing trapped air.
The 15FH520 is built with a 3" aluminum wound voice coil on a glass fiber former for reduced weight, which keeps sensitivity high, while maintaining a high continuous power handling rating of 600 watts RMS. Made in Italy.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance16 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)12.7 ohms
  • Voice Coil Inductance (Le)1.7 mH
  • Mechanical Q (Qms)13.5
  • Electromagnetic Q (Qes)0.65
  • Total Q (Qts)0.62
  • Compliance Equivalent Volume (Vas)4.44 ft.³
  • Mechanical Compliance of Suspension (Cms)0.13 mm/N
  • BL Product (BL)23.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)107g
  • Moving Mass Of Diaphragm (Mmd)93.8
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)813 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.47"
  • Baffle Cutout Diameter13.94"
  • Depth7.14"
  • Bolt Circle Diameter14.72"
  • # Mounting Holes8
  • Sealed Volume1.77 ft.³
  • Sealed F376 Hz
  • Vented Volume4.39 ft.³
  • Vented F342 Hz
  • BrandFaitalPRO
  • Model15FH520
  • Part Number294-1276
  • UPC848864008257
  • Weight10.1 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the FaitalPRO 15FH520 15" Neodymium Professional Woofer 16 Ohm
