FaitalPRO 15FH500 15" Neodymium Professional Woofer 8 Ohm
Brand:|Model: 15FH500|Part # 294-1272
For a high output pro audio woofer that mates well with horn drivers and can be used in a folded horn enclosure, choose FaitalPRO's 15FH500 15" woofer. Its 3" diameter voice coil offers up to 500 watts RMS power handling and neodymium motor keeps weight under 10 total pounds.
$290.00
Part # 294-1272
  • Lightweight neo woofer that works well in horn loaded enclosures
  • Custom cast aluminum frame
  • High 500 watt RMS power handling
  • Wide, linear frequency response
  • Made in Italy
Frequently Bought Together
FaitalPRO's 15FH500 15" professional woofer features 500 watts of RMS power handling thanks to a 3" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the M-Roll treated polycotton surround maintains linearity during heavy excursion.
The 15FH500 mates well with most any 1", 1.4", or 2" compression horn driver (with a flat frequency response from 35 to 3,150 Hz), for a great sounding large format two-way speaker. 9.25 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned reasonably low, and an EBP of 109 means the 15FH500 also works in horn loaded enclosures. Made in Italy.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,150 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.3 mH
  • Mechanical Q (Qms)10.4
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)6.37 ft.³
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • BL Product (BL)19.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)104g
  • Moving Mass Of Diaphragm (Mmd)89.7
  • Maximum Linear Excursion (Xmax)9.25 mm
  • Surface Area of Cone (Sd)800 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.47"
  • Baffle Cutout Diameter13.94"
  • Depth7.14"
  • Bolt Circle Diameter14.72"
  • # Mounting Holes8
  • Sealed Volume1.08 ft.³
  • Sealed F390 Hz
  • Vented Volume2.16 ft.³
  • Vented F356 Hz
  • BrandFaitalPRO
  • Model15FH500
  • Part Number294-1272
  • UPC848864008264
  • Weight12.05 lbs.
Pyle PBW10S 10" Midbass
Part #  292-2528
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
RCF L15P540 15" Woofer Speaker
Part #  294-860
View similar products to the FaitalPRO 15FH500 15" Neodymium Professional Woofer 8 Ohm
