FaitalPRO 15FH500 15" Neodymium Professional Woofer 16 Ohm
Brand:|Model: 15FH500|Part # 294-1273
For a high output pro audio woofer that mates well with horn drivers, choose FaitalPRO's 15FH500 15" woofer. Its 3" diameter voice coil offers up to 500 watts RMS power handling and neodymium motor keeps weight under 9-1/2 pounds.
ORDER TODAY
Ships in 7-10 Business Days
$290.00
Part # 294-1273
  • Lightweight neo woofer that works well in horn loaded enclosures
  • Custom cast aluminum frame
  • High 500 watt RMS power handling
  • Wide, linear frequency response
  • 16 ohm impedance for use in multiples
  • Made in Italy
FaitalPRO's 15FH500 15" professional woofer features 500 watts of RMS power handling thanks to a 3" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the M-Roll treated polycotton surround maintains linearity during heavy excursion.
The 15FH500 mates well with most any 1", 1.4", or 2" compression horn driver (with a flat frequency response from 35 to 3,150 Hz), for a great sounding large format two-way speaker. 9.25 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned reasonably low. A 16 ohm impedance allows for use in groups, such as a double 15" 2-way speaker. Made in Italy.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance16 ohms
  • Frequency Response35 to 3,150 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)12.7 ohms
  • Voice Coil Inductance (Le)2 mH
  • Mechanical Q (Qms)13.2
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)6.95 ft.³
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • BL Product (BL)23.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)95.4g
  • Moving Mass Of Diaphragm (Mmd)82.6
  • Maximum Linear Excursion (Xmax)9.25 mm
  • Surface Area of Cone (Sd)800 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.47"
  • Baffle Cutout Diameter13.94"
  • Depth7.14"
  • Bolt Circle Diameter14.72"
  • # Mounting Holes8
  • Sealed Volume3.03 ft.³
  • Sealed F362 Hz
  • Vented Volume8.2 ft.³
  • Vented F332 Hz
  • BrandFaitalPRO
  • Model15FH500
  • Part Number294-1273
  • UPC848864008271
  • Weight9.48 lbs.
View similar products to the FaitalPRO 15FH500 15" Neodymium Professional Woofer 16 Ohm
