FaitalPRO 12PR300 12" Neodymium Professional Woofer 8 Ohm
Brand:|Model: 12PR300|Part # 294-1241
Choose FaitalPRO's 12" 12PR300 woofer to replace or upgrade the woofer in your speaker cabinet. A flat frequency response to 5,000 Hz and high sensitivity of 99 dB (1W/1m) allows it to match well with nearly any horn driver.
$215.00
Part # 294-1241
  • Lightweight design weighs just over 5-1/2 pounds
  • 99 dB sensitivity due to high-energy neo motor
  • Durable cast-aluminum frame
  • Ultra-linear frequency response
  • Made in Italy
With high sensitivity and a ruler-flat frequency response from 50 Hz to 5,000 Hz, FaitalPRO's 12PR300 12" woofer is perfect for replacing and upgrading tired, worn-out woofers in small to large-sized, vented two-way speakers. The 12PR300 is a great choice for live sound and high output home audio speakers.
An eight-spoke, cast-aluminum frame adds structural integrity, while the treated paper cone and polycotton M-Roll surround can withstand years of constant use. The 300 watt RMS power handling rating is made possible by the use of a 2.5" voice coil on a glass fiber former. A neodymium slug motor keeps weight low, just over 5-1/2 pounds. Made in Italy.
  • Nominal Diameter12"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)50 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)0.42 mH
  • Mechanical Q (Qms)9.92
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)2.8 ft.³
  • Mechanical Compliance of Suspension (Cms)0.23 mm/N
  • BL Product (BL)14.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)43.4g
  • Moving Mass Of Diaphragm (Mmd)36.6
  • Maximum Linear Excursion (Xmax)4.92 mm
  • Surface Area of Cone (Sd)489 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.41"
  • Baffle Cutout Diameter11.06"
  • Depth5.54"
  • Bolt Circle Diameter11.75"
  • # Mounting Holes8
  • Sealed Volume0.69 ft.³
  • Sealed F3111 Hz
  • Vented Volume1.56 ft.³
  • Vented F364 Hz
  • BrandFaitalPRO
  • Model12PR300
  • Part Number294-1241
  • UPC848864008448
  • Weight7.45 lbs.
View similar products to the FaitalPRO 12PR300 12" Neodymium Professional Woofer 8 Ohm
