FaitalPRO 12FH520 12" Neodymium Professional Woofer 16 Ohm
Brand:|Model: 12FH520|Part # 294-1251
The 12" 12FH520 woofer from FaitalPRO is built with cutting-edge features for the best performance possible. Lightweight, high sensitivity and power handling, and great frequency response are hallmarks of the 12FH520. 16 ohm impedance.
Ships in 7-10 Business Days
Part # 294-1251
  • High 98 dB sensitivity
  • Low distortion neodymium motor with an aluminum shorting ring
  • 16 ohm impedance for use in double 12" 2-way speakers
  • Weighs less than 10 pounds
  • Up to 600 watts of RMS power handling
  • Linear frequency response to 4,000 Hz
  • Made in Italy
Low distortion, high effective bandwidth product (EBP), outstanding sensitivity, and great power handling are hallmarks of FaitalPRO's 12FH520 12" woofer. Add to all of this a lightweight neodymium motor with a built-in aluminum demodulation ring for low distortion, and you have one of the most cutting-edge 12" woofers in the Pro Audio industry.
A treated polycotton triple-roll surround is mated to the 12FH520's treated paper cone for durability, and the 3" aluminum voice coil is mounted on a glass fiber former for maximum heat resistance. The eight-spoke, cast-aluminum frame minimizes backwave reflection while offering maximum structural rigidity. 16 ohm voice coil for use in double 12" speaker cabinets. Made in Italy.
  • Nominal Diameter12"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance16 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)55 Hz
  • DC Resistance (Re)12.8 ohms
  • Voice Coil Inductance (Le)1.6 mH
  • Mechanical Q (Qms)17
  • Electromagnetic Q (Qes)0.48
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)1.73 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)23.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)60.5g
  • Moving Mass Of Diaphragm (Mmd)54.2
  • Maximum Linear Excursion (Xmax)7 mm
  • Surface Area of Cone (Sd)500 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.44"
  • Baffle Cutout Diameter11.12"
  • Depth6.13"
  • Bolt Circle Diameter11.75"
  • # Mounting Holes8
  • Sealed Volume0.88 ft.³
  • Sealed F393 Hz
  • Vented Volume2.36 ft.³
  • Vented F346 Hz
  • BrandFaitalPRO
  • Model12FH520
  • Part Number294-1251
  • UPC848864008370
  • Weight9.26 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the FaitalPRO 12FH520 12" Neodymium Professional Woofer 16 Ohm
