FaitalPRO 12FH500 12" Neodymium Professional Woofer 16 Ohm
Brand:|Model: 12FH500|Part # 294-1248
The 12" 12FH500 woofer from FaitalPRO is built with cutting-edge features for the best performance possible. Lightweight, high sensitivity and power handling, and great frequency response are hallmarks of the 12FH500. 16 ohm impedance.
ORDER TODAY
Ships in 7-10 Business Days
$262.00
Part # 294-1248
  • High 97 dB sensitivity
  • Neo motor keeps total weight under 10 pounds
  • Up to 500 watts of RMS power handling
  • Linear frequency response to 4,000 Hz
  • 16 ohm impedance for use in parallel sets of two
  • Made in Italy
Low distortion, high effective bandwidth product (EBP), outstanding sensitivity, and great power handling are hallmarks of FaitalPRO's 12FH500 12" woofer. Add to all of this a lightweight neodymium motor, and you have one of the most cutting-edge 12" woofers in the Pro Audio industry.
A treated polycotton M-Roll surround is mated to the 12FH500's treated paper cone for durability, and the 3" aluminum voice coil is mounted on a glass fiber former for maximum heat resistance. The eight-spoke, cast-aluminum frame minimizes backwave reflection while offering maximum structural rigidity. Made in Italy.
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance16 ohms
  • Frequency Response45 to 4,000 Hz
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)48 Hz
  • DC Resistance (Re)12.8 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)11
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)2.35 ft.³
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • BL Product (BL)23.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)55.5g
  • Moving Mass Of Diaphragm (Mmd)49.3
  • Maximum Linear Excursion (Xmax)7.25 mm
  • Surface Area of Cone (Sd)487 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.44"
  • Baffle Cutout Diameter11.12"
  • Depth6.13"
  • Bolt Circle Diameter11.75"
  • # Mounting Holes8
  • Sealed Volume0.57 ft.³
  • Sealed F3106 Hz
  • Vented Volume1.31 ft.³
  • Vented F361 Hz
  • BrandFaitalPRO
  • Model12FH500
  • Part Number294-1248
  • UPC848864008417
  • Weight8.6 lbs.
View similar products to the FaitalPRO 12FH500 12" Neodymium Professional Woofer 16 Ohm
