FaitalPRO 10FH520 10" Neodymium Professional Midbass Woofer 8 Ohm
Brand:|Model: 10FH520|Part # 294-1211
Choose the lightweight, neodymium-powered FaitalPRO 10FH520 10" woofer for high output midbass and midrange duties.
Part # 294-1211
  • Well suited for high power midbass, and midrange use
  • 3" aluminum voice coil and a lightweight, powerful neo slug motor
  • Distortion and inductance reducing aluminum demodulation ring
  • Open cast aluminum frame allows driver to move freely
  • Made in Italy
FaitalPRO's 10FH520 10" neodymium woofer is designed for maximum midbass punch and midrange clarity and clocks in at just over 10 pounds. An aluminum demodulation ring in the motor reduces inductance for a frequency response that extends up to 4,000 Hz, while reducing distortion. Its open cast aluminum basket makes this speaker structurally solid, while minimizing trapped air.
The 10FH520 is built with a 3" aluminum wound voice coil on a glass fiber former for reduced weight, which keeps sensitivity high, while maintaining a high continuous power handling rating of 600 watts. A low Qts rating of 0.29 allows this woofer to be used in modest sized sealed cabinets, making it great for monitor use or in large format three-way speakers as a dedicated midrange. Made in Italy.
  • Nominal Diameter10"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)60 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)11.1
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)0.72 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)18 Tm
  • Diaphragm Mass Inc. Airload (Mms)50.3g
  • Moving Mass Of Diaphragm (Mmd)47
  • Maximum Linear Excursion (Xmax)7.25 mm
  • Surface Area of Cone (Sd)321 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.28"
  • Baffle Cutout Diameter9.06"
  • Depth5.56"
  • Bolt Circle Diameter9.69"
  • # Mounting Holes4
  • Sealed Volume0.11 ft.³
  • Sealed F3165 Hz
  • Vented Volume0.21 ft.³
  • Vented F3105 Hz
  • BrandFaitalPRO
  • Model10FH520
  • Part Number294-1211
  • UPC848864008509
  • Weight9.55 lbs.
View similar products to the FaitalPRO 10FH520 10" Neodymium Professional Midbass Woofer 8 Ohm
