FaitalPRO 10FH500 10" Neodymium Professional Midbass Woofer 16 Ohm
Brand:|Model: 10FH500|Part # 294-1210
The FaitalPRO 10FH500 10" neodymium midbass woofer is a great choice for high output midbass and midrange duties.
Ships in 7-10 Business Days
Part # 294-1210
  • Well suited for high power midbass, and midrange use
  • 3" aluminum voice coil and a lightweight, powerful neo slug motor
  • Open cast aluminum frame allows driver to move freely
  • Made in Italy
Frequently Bought Together
FaitalPRO's 10FH500 10" neodymium woofer is designed for maximum midbass punch and midrange clarity and clocks in at just over 7-1/2 pounds. Its open cast aluminum basket makes this speaker structurally solid, while minimizing trapped air.
The 10FH500 is built with a 3" aluminum wound voice coil on a glass fiber former for reduced weight, which keeps sensitivity high, while maintaining a high continuous power handling rating of 500 watts. A low Qts rating of 0.4 allows this woofer to be used in modest sized sealed cabinets, making it great for monitor use or in large format three-way speakers as a dedicated midrange. Made in Italy.
  • Nominal Diameter10"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance16 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)65 Hz
  • DC Resistance (Re)12.8 ohms
  • Voice Coil Inductance (Le)1.37 mH
  • Mechanical Q (Qms)5.7
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.68 ft.³
  • Mechanical Compliance of Suspension (Cms)0.12 mm/N
  • BL Product (BL)23.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)47.5g
  • Moving Mass Of Diaphragm (Mmd)44.1
  • Maximum Linear Excursion (Xmax)7.25 mm
  • Surface Area of Cone (Sd)328 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.28"
  • Baffle Cutout Diameter9.06"
  • Depth5.56"
  • Bolt Circle Diameter9.69"
  • # Mounting Holes4
  • Sealed Volume0.22 ft.³
  • Sealed F3130 Hz
  • Vented Volume0.54 ft.³
  • Vented F371 Hz
  • BrandFaitalPRO
  • Model10FH500
  • Part Number294-1210
  • UPC848864008554
  • Weight7.5 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the FaitalPRO 10FH500 10" Neodymium Professional Midbass Woofer 16 Ohm
