092-604_ALT_0
092-604_ALT_1
F-Conn Commercial RCA Male Connector RGB 24-26 Ga. 5 Pcs.
Brand:|Part # 092-604
F-Conn commercial grade broadband connectors meet the rugged demands of home and commercial cabling use. They compress in a true 360° fashion which reduces impedance issues over standard crimp-type connectors.
Part # 092-604
  • No soldering
  • Full 360 ° compression
  • Can withstand more than 80 pounds of pullout force
  • Radial design reduces impedance problems
  • Internal "O" sealing rings prevent moisture migration
  • AT&T approved
  • Meets SCTE-IPC and Bellcore requirements
F-Conn commercial grade broadband connectors meet the rugged demands of home and commercial cabling use. They compress in a true 360° fashion which reduces impedance issues over standard crimp-type connectors. Internal "O" rings prevent moisture from entering the connector making them perfect for high moisture applications. Sold in packs of 5. Requires the use of F–Conn compression tool , our part number 092-684.
Specifications: • Contact plating: nickel • Sold per: 5 pack • Entry hole: 8mm • Termination style: F-Conn compression • Dimensions: 0.4" x 1.375"
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • BrandF-Conn
  • Part Number092-604
  • UPC844632008825
  • Product CategoryRCA Connectors
  • Unit of MeasurePK
  • Weight0.25 lbs.
View similar products to the F-Conn Commercial RCA Male Connector RGB 24-26 Ga. 5 Pcs.
in the RCA Connectors product category.
