F-Conn Commercial RCA For Wall Plate System RG-59 5 Pcs.
Brand:|Model: FS59RCAUS|Part # 092-712
F-Conn's "wall plate" connectors are designed to be used with the new Wall Plate System. Installers now use the same wall plate and insert for every installation, the only difference is the connector that is used.
  • No soldering
  • Full 360 ° compression
  • Can withstand more than 80 pounds of pullout force
  • Radial design reduces impedance problems
  • Internal "O" sealing rings prevent moisture migration
F-Conn's "wall plate" connectors are designed to be used with the new Wall Plate System. Installers now use the same wall plate and insert for every installation, the only difference is the connector that is used. The connectors are professional grade that meet the rugged demands of the home and commercial cabling market. They provide true 360° of compression which provide over 80 pounds of pulling force. Internal "O" rings prevent moisture from entering the connector making them perfect for high moisture applications. Only compatible with F-Conn's keystone jacks. Available in BNC, RCA, and "F". Sold in packs of 5. Requires the use of F–Conn compression tool , our part number 092-684.
  • BrandF-Conn
  • ModelFS59RCAUS
  • Part Number092-712
  • UPC844632058042
  • Product CategoryWall Plate Hex Connectors & Adapters
  • Unit of MeasurePK
  • Weight0.2001 lbs.
View similar products to the F-Conn Commercial RCA For Wall Plate System RG-59 5 Pcs.
in the Wall Plate Hex Connectors & Adapters product category.
