EV EVX-180B 18" Extended LF Speaker Driver
Brand:|Model: EVX-180B|Part # 294-565
Designed for pro sound reinforcement and studio monitoring or subwoofer applications that require maximum output with low distortion. The EVX woofers provide unprecedented power handling capacity, linearity and excursion...
Comparable Items In Stock:
Part # 294-565
Designed for sound reinforcement and studio monitoring applications that require maximum output with low distortion. The EVX woofers provide unprecedented power handling capacity, linearity and excursion made possible by HeatWick, a proprietary design that actually wicks the heat away from the huge 4" voice coil. Ribbed Kevlar fiber composite cone.
  • Nominal Diameter18"
  • Power Handling (RMS)1000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response20 to 2,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight292.8 oz.
  • Resonant Frequency (Fs)29 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.6 mH
  • Mechanical Q (Qms)4
  • Electromagnetic Q (Qes)0.29
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)14.7 ft.³
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • Maximum Linear Excursion (Xmax)6.4 mm
  • Surface Area of Cone (Sd)1220 cm²
  • Cone MaterialPaper / Kevlar
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.2"
  • Baffle Cutout Diameter16.6"
  • Depth7.92"
  • # Mounting Holes8
  • BrandElectro-Voice
  • ModelEVX-180B
  • Part Number294-565
  • UPC701001011360
    (4 Reviews)
  • Weight28.4 lbs.
View similar products to the EV EVX-180B 18" Extended LF Speaker Driver
