ESS 689-1012 10" Cast Frame Woofer Speaker
Brand:|Model: 689-1012|Part # 264-620
The ESS 689-1012 10" woofer mates perfectly with the ESS AMT-1 Air Motion Transformer, as well as offering great performance in almost any high-quality audio application.
Part # 264-620
  • Treated and reinforced paper cone with rubber half-roll surround
  • Attractive, sturdy cast aluminum frame keeps components in alignment
  • Pure copper 1-1/2" voice coil wound on black aluminum former provides high power handling
  • Linear suspension system and bumped back plate for maximum bass
  • Highly conductive/fatigue resistant woven tinsel leads
  • Superior transient response guarantees highly accurate sound reproduction
  • Drop-in replacement for the ESS AMT Monitor speaker system
Famous for the superb Air Motion Transformer mid/high transducer, ESS also manufactures woofers that match the AMT's quality and performance. The ESS 689-1012 10" woofer features a specially coated and reinforced paper cone with half-roll rubber surround, the combination of which provides a perfect balance of mass, rigidity, and good linear excursion capabilities.
A cast aluminum frame protects and aligns the woofer's critical moving components, as well as avoiding the diversion or dissipation of the 35 oz. ceramic magnet's high motor strength. Highly conductive and fatigue resistant woven tinsel leads establish a reliable connection between the high-power 1-1/2" copper voice coil and the oxidation resistant gold-plated input terminals.
  • Nominal Diameter10"
  • Power Handling (RMS)80 Watts
  • Power Handling (max)160 Watts
  • Impedance4 ohms
  • Frequency Response43 to 2,000 Hz
  • Sensitivity90.6 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)27 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)4.1
  • Electromagnetic Q (Qes)0.54
  • Total Q (Qts)0.48
  • Compliance Equivalent Volume (Vas)1.75 ft.³
  • Maximum Linear Excursion (Xmax)4 mm
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.625"
  • Baffle Cutout Diameter9.375"
  • Depth4.5"
  • # Mounting Holes4
  • Sealed Volume0.93 ft.³
  • Sealed F345 Hz
  • Vented Volume2.51 ft.³
  • Vented F322 Hz
  • BrandESS Labs Inc.
  • Model689-1012
  • Part Number264-620
  • UPC844632092695
  • Product CategoryWoofers
    (3 Reviews)
  • Weight7 lbs.
View similar products to the ESS 689-1012 10" Cast Frame Woofer Speaker
