Erse Super Q 20mH 16 AWG 500W Inductor
ERSE Super Q 20mH 16 AWG 500W Inductor
Brand:| Model: ESQ55-16-20000
Finally, a sonically superior magnetic core coil! The Super Q line features a specially shaped core that allows for optimal magnetic performance and increases the coil's effective permeability. The result is extremely low DC resistance, reduced distortion and very high saturation levels.
266-960
Weight: 1.76 lbs.
IN STOCK
$38.79
Buy 10-up$35.38
Part # 266-960
Finally, a sonically superior magnetic core coil! The Super Q line features a specially shaped core that allows for optimal magnetic performance and increases the coil's effective permeability. The result is extremely low DC resistance, reduced distortion and very high saturation levels. The coils are encapsulated in a plastic housing, which eliminates any magneto striction distortion and makes mounting a breeze. The 500 watt power rating makes these coils perfect for high power prosound applications. Made in the USA.
Specifications: • Inductance 20.0 mH • Wire gauge: 16 AWG • DC resistance 0.558 Ohms • Power handling: 500 watts RMS • Dimensions: 4-1/2" L x 1-5/8" H.
  • Inductance20 mH
  • Wire Gauge16 AWG
  • BrandERSE Audio
  • ModelESQ55-16-20000
  • Part Number266-960
  • UPC844632045721
  • Product CategorySolid Core Inductors
    (2 Reviews)
  • Weight1.76 lbs.
View similar products to the ERSE Super Q 20mH 16 AWG 500W Inductor
in the Solid Core Inductors product category.
Erse Super Q 20mH 16 AWG 500W Inductor is rated 4.0 out of 5 by 2.
Rated 4 out of 5 by from EffectiveIf used alone, this inductor is quite effective as a low-pass filter. Use it in as the higher value inductor in a 4th-order butterworth configuration to really cut off anything above 150Hz going to the woofer. Pricy, but effective.
Date published: 2013-01-14
Rated 4 out of 5 by from A must for optimum sub performanceI have a 15" dvc sub with a Bash 500 subwoofer amplifier that benefits hugely from these pups (one per voice coil works much better). Most new school "experts" will offer that today's amps with active crossovers no longer require chokes, and in fact will suffer due to the added resistance. Yes and no. The benefit lies in how much better your amp will perform given the big increase in back EMF. It's almost always a plus that outweighs the minus, moreso with a good choke. My experience is with 4 and 8ohm drivers; with a 2 ohm dvc sub, the choke/resistance factor admittedly looms larger, the results for which I cannot attest to. In any case, it is no accident names like JL Audio and Tang Band (and even some of Dayton's) have built a reputation or are critically acclaimed, as their subs are designed with lots of inductance. The chokes are a cost factor, unfortunately, (price of copper is going through the roof!), but they sure do make a difference. One try will convert you doubters!
Date published: 2011-02-17
Customer projects that include: ERSE Super Q 20mH 16 AWG 500W Inductor
