Eminence Red Coat ReignMaker 12" Guitar Speaker 75W 16 Ohm
Brand:|Model: ReignMaker |Part # 290-883
The Eminence ReignMaker 12" speaker adds a new dimension to achieving the ultimate guitar tone!
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-883
  • Dial-in your own sound
  • Patent-pending FDM technology
  • Zurette dustcap
Frequently Bought Together
Add a new dimension to achieving the ultimate guitar tone! The ReignMaker™ from Eminence uses patent-pending FDM™ technology to make changing speaker response as simple as twisting a dial. Turning the modulator knob to adjust speaker output and amplifier interaction will help you find that sweet spot of saturated tube tone—but at a significantly lower volume. Tweak the knob for a wide range of tones: more attenuation gives a warmer tone, while less attenuation restores volume and brightness. The ReignMaker features a stamped steel frame, 38 oz. ceramic ferrite magnet, Zurette dustcap, and a full molded paper cone with paper edge.
Specifications: • Power handling: 75 watts RMS • VCdia: 1.75" • Impedance: 16 ohms • Frequency range: 80-6,200 Hz • SPL: 100 dB (No knob turn), 100 dB (Full turn) • Dimensions: Overall diameter: 12.03", Cutout diameter: 10.95", Depth: 6.56".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
  • TypeLead / Rhythm Guitar
  • Nominal Diameter12"
  • Impedance16 ohms
  • Power Handling (RMS)75 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelReignMaker
  • Part Number290-883
  • UPC876358002016
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
  • Weight10.05 lbs.
View similar products to the Eminence Red Coat ReignMaker 12" Guitar Speaker 75W 16 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
