290-844_ALT_0
290-844_ALT_1
290-844_ALT_1
Eminence Red Coat Private Jack 12" Guitar Speaker 16 Ohm
Brand:| Model: Red Coat Private Jack 16
Eminence Red Coat Private Jack – Thick and smooth, with lots of mids and extended highs. Very well balanced speaker. Classic British flavor. • Power handling: 50 watts RMS • Impedance: 16 ohms • Frequency Range: 70-5,500 Hz • Sensitivity: 100.3 dB 1W/1m
  • Application: 12" Open or Closed Back
  • Configuration: 1, 2, or 4 x 12"
  • Thick and smooth, with lots of mids and extended highs. Very well balanced speaker.
  • Genre: Classic British tone for Blues, Indie, Jazz
290-844
Weight: 10 lbs.
IN STOCK
$94.99
Part # 290-844
It all started with the British Invasion, that unmistakable sound that took America by storm from across the Atlantic to right in your face. And now Eminence puts it within easy reach with the Red Coat™ series of guitar amp speakers. Engineered and manufactured in the U.S. with British-inspired cones, making it easy to "Pick Your Sound." Seven-year manufacturer's warranty.
pri'vate jack - n. namesake of the famous British canine and one of the most recognized British tones for guitar
Specifications: • Power handling: 50 watts RMS • VCdia: 1.75" • Impedance: 16 ohms • Frequency Range: 70-5,500 Hz • Sensitivity: 100.3 dB 1W/1m • Magnet weight: 38 oz. • Dimensions: Overall diameter: 12.02", Cutout diameter: 10.97", Depth: 5.1".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
  • TypeLead / Rhythm Guitar
  • Nominal Diameter12"
  • Impedance16 ohms
  • Power Handling (RMS)50 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelRed Coat Private Jack 16
  • Part Number290-844
  • UPC876358001156
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (2 Reviews)
  • Weight10 lbs.
View similar products to the Eminence Red Coat Private Jack 12" Guitar Speaker 16 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Red Coat Private Jack 12" Guitar Speaker 16 Ohm is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Nice voxish chimeThis is a great speaker for that beatles voxish type of top end chime. The low end and mids are nice, the mids are buttery and the lows are a little slagish, not a heavy metal speaker. This speaker shined most on clean tones with some verb and chorus, has a high DB so it can be loud with low wattage tube amps
Date published: 2011-05-23
Rated 5 out of 5 by from Smooooth sounding guitar speaker!I used a pair of these in a 50w guitar combo project modeled after a Marshall 1987 head. In an open back combo cabinet these just sound huge, with nice warm cleans, and "green" sounding overdrive tones, but without the shrill (and the coin). These speakers just refuse to put out harsh sounding tones. Very nice!
Date published: 2009-01-10
Customer projects that include: Eminence Red Coat Private Jack 12" Guitar Speaker 16 Ohm
