Eminence PX2:3K5 2-Way Speaker Crossover 3,500 Hz
Brand:|Model: PX2:3K5|Part # 290-622
Eminence px crossovers feature advanced circuit design to both preserve the crossover and your HF drivers. The cabinet-ready design makes installation a snap while the fitted hardware gives you that "factory-fit" finish.
  • Designed specifically for high-power cabinets
  • Cabinet-ready design makes installation a snap
  • Complete with fitted hardware for that "factory-fit" finish
  • Crossover type: Two-way, cabinet ready
  • Crossover frequencies: 3,500 Hz, 18 dB/octave HP, 12 dB/octave LP
  • Power handling: 400 watts RMS
  • Mounting cut-out: 6" x 3.875"
Eminence px cabinet-ready crossovers feature advanced circuit design to both preserve the crossover and your HF drivers. A common crossover problem is L-pad failure brought about by winding burnout when maximum attenuation is prolonged. Full attenuation concentrates the maximum voltage drop in a small winding area - a potentially damaging state even with high-power L-pad devices. In px crossovers, current is limited when the high frequency level control is set to '0' on its scale (±9 dB attenuation). A secondary benefit of the design is to form a voltage divider across the high frequency driver. The high-pass protection uses custom-built aerospace lamps. The tungsten filaments effectively track the program material, dynamically maintaining a safe maximum current level to the high frequency driver without introducing distortion. This circuitry provides smooth 3:1 analog compression during input overload conditions over 250 watts RMS. At full drive level approaching clipping, the electrical attenuation to the protected high frequency driver is -4.5 dB. In every way, Eminence px crossovers are a technically superior product. For use with 8 ohm drivers.
  • Crossover Type2-Way
  • ConfigurationIncludes Connector Dish
  • BrandEminence Speaker
  • ModelPX2:3K5
  • Part Number290-622
  • UPC876358001408
  • Product CategoryAssembled Passive Crossovers
    (2 Reviews)
  • Weight1.5 lbs.
View similar products to the Eminence PX2:3K5 2-Way Speaker Crossover 3,500 Hz
in the Assembled Passive Crossovers product category.
