290-610_ALT_0
Eminence PX:250 Low Pass Crossover 250 Hz
Brand:| Model: PX:250
Eminence px crossovers feature advanced circuit design to both preserve the crossover and your HF drivers. The cabinet-ready design makes installation a snap while the fitted hardware gives you that "factory-fit" finish.
  • Designed specifically for high-power cabinets
  • Cabinet-ready design makes installation a snap
  • Complete with fitted hardware for that "factory-fit" finish
  • Crossover type: Low-pass, cabinet ready
  • Crossover frequency: 250 Hz, 12 dB/octave
  • Power handling: 600 watts RMS
  • Mounting cut-out: 6" x 3.875"
290-610
Weight: 1.5 lbs.
IN STOCK
$59.99
Part # 290-610
Eminence px cabinet-ready crossovers feature advanced circuit design to both preserve the crossover and your HF drivers. A common crossover problem is L-pad failure brought about by winding burnout when maximum attenuation is prolonged. Full attenuation concentrates the maximum voltage drop in a small winding area - a potentially damaging state even with high-power L-pad devices. In px crossovers, current is limited when the high frequency level control is set to '0' on its scale (±9 dB attenuation). A secondary benefit of the design is to form a voltage divider across the high frequency driver. The high-pass protection uses custom-built aerospace lamps. The tungsten filaments effectively track the program material, dynamically maintaining a safe maximum current level to the high frequency driver without introducing distortion. This circuitry provides smooth 3:1 analog compression during input overload conditions over 250 watts RMS. At full drive level approaching clipping, the electrical attenuation to the protected high frequency driver is -4.5 dB. In every way, Eminence px crossovers are a technically superior product. For use with 8 ohm drivers.
  • Crossover TypeLow Pass
  • ConfigurationIncludes Connector Dish
  • BrandEminence Speaker
  • ModelPX:250
  • Part Number290-610
  • UPC876358001361
  • Product CategoryAssembled Passive Crossovers
  • Weight1.5 lbs.
View similar products to the Eminence PX:250 Low Pass Crossover 250 Hz
in the Assembled Passive Crossovers product category.
WILL THIS WORK FOR THE PEAVEY 118 SUBS
Asked by: SUPERJOCK
Yes they will work with the peavey sp118 subs but you can not change the crossover frequency. The better option in pro audio would be to use an active crossover.
Answered by: TomI
Date published: 2014-10-09
will this work with a three way speaker system I use Celestion   speaker box but everything has been replaced including   the crossover pc board I want   to mount on my back  and the cut out is almost the right RO to mount and I use 8 Ohm speakers 250amp
Asked by: Chrisbyars
Unfortunately there are too many variables to give you a straight answer here. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-07-21
can this work well on my EAW SB730. cabinet that I'm trying to repair
Asked by: ochim002
I would only recommend the factory crossover for this cabinet. It is designed to handle twice the power and work specifically with the stock drivers.
Date published: 2014-02-14
Is this crossover good for my eminence lab 12
Asked by: DJBPM
This will work for a Lab 12 woofer without a problem.
Date published: 2014-02-10
Will this crossover work with this speaker (B&C 15CXN76 15" Neodymium Coaxial ) ?
Asked by: Dbassdbt
Unfortunately no since this is just a low pass. You will want a two way crossover for that speaker.
Date published: 2013-12-16
  • 2015-05-06T08:28CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_290-610, PRD, sort_recentQuestionsFirst
Customer projects that include: Eminence PX:250 Low Pass Crossover 250 Hz
