290-466_ALT_0
290-466_ALT_1
Eminence Legend CA154 15" Bass Guitar Driver 4 Ohm
Brand:| Model: Legend CA154
Pro sound 15" woofer for use in bass guitar cabinets or in PA loudspeaker systems. 4-ohm driver with high sensitivity.
  • Stamped steel basket
  • Copper voice coil wound on a polyimide former
  • Vented pole piece
  • For bass guitar and PA applications
  • 4 ohm nominal impedance
290-466
Weight: 14 lbs.
IN STOCK
List Price$104.99
Regular Price$99.99
You Save15%
Special Price
$84.99
Part # 290-466
Pro sound 15" woofer for use in bass guitar cabinets or in PA loudspeaker systems. 4-ohm driver with high sensitivity. Stamped steel basket, copper voice coil wound on a polyimide former, and vented pole piece. Suitable for 1.4 to 2.5 cu. ft. sealed enclosures or 1.6 to 6 cu. ft. vented.
Specifications: • Power handling: 300 watts RMS/600 watts max • VCdia: 2-1/2" • Le: 0.80 mH • Impedance: 4 ohms • Re: 2.92 ohms • Frequency range: 45-3,000 Hz • Magnet weight: 56 oz. • Fs: 51 Hz • Sensitivity: 96.9 dB 1W/1m • Vas: 3.82 cu. ft. • Qms: 4.94 • Qes: 0.54 • Qts: 0.49 • Xmax: 5 mm • Dimensions: Overall Diameter: 15.15", Cutout Diameter: 13.87", Depth: 6.25".
  • TypeBass Guitar
  • Nominal Diameter15"
  • Impedance4 ohms
  • Power Handling (RMS)300 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelLegend CA154
  • Part Number290-466
  • UPC876358001484
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (4 Reviews)
  • Weight14 lbs.
View similar products to the Eminence Legend CA154 15" Bass Guitar Driver 4 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Legend CA154 15" Bass Guitar Driver 4 Ohm is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from BETTER then the original--Install in a bass amp--sounds much better then the original--I won't disclose the brand name.
Date published: 2014-04-08
Rated 3 out of 5 by from bought to use for jammingfound that I had to use a lot of power to keep up with the guitarist.. much more than a 1990 combo amp I have with a single 15. good spare speaker, but that about it. all the other items worked very wrll.
Date published: 2014-02-04
Rated 5 out of 5 by from Well Worth Looking Into!I found a acoustic B200 cabinet with no 15" speaker. Had been looking for a speaker,but just couldn't find the one I wanted,so I purchased this one. So glad I did. Nice!! sound.Speaker fit right in the cabinet,no problems. So far I have only got the amp up too around 4.WOW!!! Its loud and full.I know where my next speaker will come from!!
Date published: 2013-08-19
Rated 5 out of 5 by from Darned good speaker for the priceI used one of these in a ported bass guitar cab project to pair with an all tube Ampeg SVT, as it fits the bill with it being 4 ohms. Lots of low end on tap, with very good sensitivity. Very old school sounding driver. If You're looking to build a decent sounding cabinet for not a lot of money these are the way to go.However, I will add that if I were gonna use one of these for a more modern sounding cab. I would recomend using it in conjunction with a Mid or HF driver and crossover, as it does seem to roll off the highs just a bit for that kind of sound.
Date published: 2013-09-15
Customer projects that include: Eminence Legend CA154 15" Bass Guitar Driver 4 Ohm
