Eminence Legend CA154 15" Bass Guitar Driver 300W 4 Ohm
Brand:|Model: Legend CA154|Part # 290-466
Pro sound 15" woofer for use in bass guitar cabinets or in PA loudspeaker systems. 4-ohm driver with high sensitivity.
$89.99
Part # 290-466
  • Stamped steel basket
  • Copper voice coil wound on a polyimide former
  • Vented pole piece
  • For bass guitar and PA applications
  • 4 ohm nominal impedance
Pro sound 15" woofer for use in bass guitar cabinets or in PA loudspeaker systems. 4-ohm driver with high sensitivity. Stamped steel basket, copper voice coil wound on a polyimide former, and vented pole piece. Suitable for 1.4 to 2.5 cu. ft. sealed enclosures or 1.6 to 6 cu. ft. vented.
Specifications: • Power handling: 300 watts RMS/600 watts max • VCdia: 2-1/2" • Le: 0.80 mH • Impedance: 4 ohms • Re: 2.92 ohms • Frequency range: 45-3,000 Hz • Magnet weight: 56 oz. • Fs: 51 Hz • Sensitivity: 96.9 dB 1W/1m • Vas: 3.82 cu. ft. • Qms: 4.94 • Qes: 0.54 • Qts: 0.49 • Xmax: 5 mm • Dimensions: Overall Diameter: 15.15", Cutout Diameter: 13.87", Depth: 6.25".
  • TypeBass Guitar
  • Nominal Diameter15"
  • Impedance4 ohms
  • Power Handling (RMS)300 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelLegend CA154
  • Part Number290-466
  • UPC876358001484
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (7 Reviews)
  • Weight14 lbs.
View similar products to the Eminence Legend CA154 15" Bass Guitar Driver 300W 4 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Legend CA154 15" Bass Guitar Driver 300W 4 Ohm is rated 4.7143 out of 5 by 7.
Rated 5 out of 5 by from I've tried, but the CA154 refuses to die.Purchased this speaker to replace the original 15" Jensen that fires into the mechanical bass rotor on a 50-year-old Leslie Model 21H. The original bass speaker on a second Leslie just blew (it was also showing its age), and I knew exactly where to turn and the speaker I wanted to take its place.The Eminence easily handles the true +300 watt signal it sometimes finds itself receiving, and it doesn't snap, crackle, pop or otherwise protest when the frequency response might wander above its rated 3,000 Hz.As the louver visible in the photo shows, a Leslie cabinet doesn't come close to being sealed or ported as the specs suggest, or as it would likely be used in a home audio setup where a 300 pound keyboard isn't being wielded in a live music venue to deafen 500 people. Yet despite all the non-spec abuse sent its way, it routinely takes a licking and keeps on ticking.Blown Leslie speakers are a notorious part of the cost of doing business in this business. For its price, the CA154 delivers a ton of value while stubbornly refusing to die. As a bass cab replacement speaker (the Leslie market is admittedly on the small side), the CA154 will do just fine. And considering what you paid for the thing, you can easily afford to bring along a spare.
Date published: 2015-06-29
Rated 5 out of 5 by from good speakerI bought this speaker thinking that my speaker was blown. Turns out it wasn't. This thing really kicked. I hooked it up to a 300 watt amp and was surprised at the sound of it for the price. Its definitely worth the price. If i ever need any thing like this again, im buying it here.
Date published: 2015-02-17
Rated 5 out of 5 by from Eminence CA154 Bass Guitar SpeakerLoved it ! Great Product ! Great Price ! Fast Delivery !!!
Date published: 2014-10-01
Rated 5 out of 5 by from BETTER then the original--Install in a bass amp--sounds much better then the original--I won't disclose the brand name.
Date published: 2014-04-08
Rated 3 out of 5 by from bought to use for jammingfound that I had to use a lot of power to keep up with the guitarist.. much more than a 1990 combo amp I have with a single 15. good spare speaker, but that about it. all the other items worked very wrll.
Date published: 2014-02-03
Rated 5 out of 5 by from Well Worth Looking Into!I found a acoustic B200 cabinet with no 15" speaker. Had been looking for a speaker,but just couldn't find the one I wanted,so I purchased this one. So glad I did. Nice!! sound.Speaker fit right in the cabinet,no problems. So far I have only got the amp up too around 4.WOW!!! Its loud and full.I know where my next speaker will come from!!
Date published: 2013-08-08
  • 2016-02-14T06:48CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_290-466, PRD, sort_mostRecent
where it the size measured.
Asked by: knucklehead
A speaker is measured across the whole metal frame.
Date published: 2015-05-06
Can I series two of these speakers together for an 8 ohm load and use a passive radiator as a ported box. If so what size box would I use and what size passive radiator will be needed. I am going to use a Bogen MT 250 power amp. 250 watt's, 600 watt peak?
Asked by: marksbass
These will not work well with passive radiators. I would recommend a standard vented cab that is 6.3 cubic feet for both, with two 4" diameter holes in the box (3/4" port length) for a tuning frequency of 45 Hz.
Date published: 2015-01-28
Want to replace the woofer in my swr workingmans 15 bass combo,will this work?
Asked by: Bambu
Yes this driver will work as a replacement for that amp.
Date published: 2014-08-25
  • 2016-02-14T07:41CST
  • loc_en_US, sid_290-466, PRD, sort_recentQuestionsFirst
