290-470_ALT_0
290-470_ALT_1
Eminence Legend BP102-4 10" Bass Guitar Driver 4 Ohm
Brand:| Model: Legend BP102-4
The Legend BP102 has been a staple product for many bass guitar wonders over the past 10 years. Now available in 4 ohms!
  • Recommended for bass guitar applications
  • Outstanding performance in sealed or vented enclosures
  • Works well in single or multi-driver designs
  • Low Fs, good power handling, 6.2 mm Xmax
290-470
Weight: 8.9 lbs.
IN STOCK
$84.99
Part # 290-470
The Legend BP102 has been a staple product for many bass guitar wonders over the past 10 years. This is a favorite for 3x, 4x, and 8x10 cabinets! Now available in 4 ohms! Don't let the sensitivity fool you, this speaker will really punch out the bass with authority. Perfect replacement driver for many popular 1x10 combo amps that require a 4 ohm 10" speaker. It also works great as a mid in PA applications or in a three-way bass cabinet. Made in the USA. 7-year manufacturer's warranty!
Specifications: • Power handling: 200 watts RMS • VCdia: 2" • Impedance: 4 ohms • Frequency range: 40-2,000 Hz • Sensitivity: 90.5 dB 1W/1m • Fs: 34.5 Hz • Magnet weight: 38 oz. • Dimensions: Overall diameter: 10.08", Cutout diameter: 9.05", Depth: 4.25".
No other speaker is used more widely as standard equipment in guitar and bass guitar amplifiers than Eminence! Most guitar speaker manufacturers are well known for a specific type of tone. Indeed Eminence is recognized for establishing the "American" rock, country, and blues tones. What really sets Eminence apart though is the ability to provide the guitarist with virtually any tone they desire! Rock, Metal, Country, Blues, British, Rap, Soul, and Alternative styles can be provided with one of the Legend models available. If you're not packing a Legend, you're probably not playing like one!
  • TypeBass Guitar
  • Nominal Diameter10"
  • Impedance4 ohms
  • Power Handling (RMS)200 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelLegend BP102-4
  • Part Number290-470
  • UPC876358000821
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (7 Reviews)
  • Weight8.9 lbs.
View similar products to the Eminence Legend BP102-4 10" Bass Guitar Driver 4 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Legend BP102-4 10" Bass Guitar Driver 4 Ohm is rated 5.0 out of 5 by 7.
Rated 5 out of 5 by from Awesome SauceI deployed this speaker in a single-box-portable bass amp set up with supply and amp inside the cabWinISD indicates that an 18" OD cube provides the needed 2.7cuFt internal volume. I used 2@ 2" PVC ports rather than a single 4" port. I lined the cab with acoustic egg crate foam.The result is a classic paper cone bass sound. And with 200W speaker rating, I can drive the cab with an external head when I need a wall of sound.May I repeat - Awesome Sauce !!!
Date published: 2013-08-18
Rated 5 out of 5 by from Why didn't I just do this sooner... Sounds great and worth the money!!I had been needed to replace the speakers in my bass cabinet in my band room. I had a professional bass player friend highly recommended me these speakers. He is a blues/rock basest. Anyways, I finely placed the order and within 5 days received my two Eminence bass speakers. I installed them with ease and wow. My bass amp sounded awesome. It was everything I had hoped for. Great product and great turn around. Wish I had done this sooner...Rock On!!
Date published: 2013-05-16
Rated 5 out of 5 by from Replacement Speaker for my Custom Bass CabinetI am a keyboard and bass player.I built a 32Hz ported Cabinet eight years ago that could handle 175w (250w max) at 4oms. In a jam in a small room (1000sf), the dang guitarists kept turning up their volume to compete with each other. ?Has this ever happened to you? Needless to say, I fried the woofer during my organ solo.I have been looking for a speaker that I could cross-over at 2000Hz, could go low (down to Low B) and would handle 200w as well as have an SPL over 90Hz. A bass player at church had a small 10" rig and told me about this speaker. Well, it had everything I needed and a decent SPL.This is an American made speaker, made for Bass Guitar Cabinets. I am still breaking it in but it sounds better than the high dollar HiFi speaker I had in it.I highly recommend the Speaker. Next I will build a 600w Cab and use 4 of these speaker.
Date published: 2013-05-11
Rated 5 out of 5 by from Best bang for your bass!I've been playing bass for 4 yrs and I have, like many others, been in search for the killer tone. I tried everything short of shelling out big bucks for a $1000 + cab. So I decided instead to build me a 210 cab, and put in it what many of the $1000+ cabs have in theirs-Eminence. Everything Eminence; the crossover; the horn and compression driver. The end result was a tone I never expected. I based the size of the cab on a popular Mark Bass cab. I used a port size calculator to determine the port size to used. Got all my parts from parts express. The BP102's gives deep warm low end bass. Once the voice coils loosen after some time, the bass becomes deeper and more punchy. You simply can't go wrong with Eminence.
Date published: 2012-07-17
Rated 5 out of 5 by from Awesome Bass Speakers!My SWR Goliath III 4 ohm cabinet has just been re-born better than ever, better than new with these speakers.I had no idea what great sound and punch I was missing until I replaced my original SWR PAS drivers with these!The BP102-4 speaker fit perfectly in the Goliath III cabinet and I wired them in series/parallel for 4 ohm total load.My Markbass Littlemark Tube 800 sounds great through these.Highly recommended, these are the real deal!
Date published: 2011-10-22
Rated 5 out of 5 by from Mid-Bass in your face!!!!Bought 2 of these to replace my Peavey 210 cabinet and they are far better than I remember this cabinet sounding...will replace my 15" cabinet with another Eminence Delta Low freq. Great service and price!
Date published: 2012-07-15
Need 8 ohm 2x10 bass cab (converted from 4 ohm 2x10 bass cab)
I have a 2x10 bass cab rated at 4 ohms, 400 watts. I need to convert it to an 8 ohm cab. Will the two of the Eminence Legend BP102-4 10" bass drivers wired correctly, I believe in parallel, give me this. And, what would be the wattage rating on two of these wired this way?
Asked by: classicrocker
Wiring two of these Eminence drivers in series (not parallel) will give you an 8 ohm load. When wired in series, the effective impedance of a speaker system is the sum of the impedances of the individual drivers. The total power handling will be the sum of the power handling of the individual drivers, which are each 200W, so total power handling will be 400W.
Answered by: eboyer
Date published: 2011-12-05
How to wire 2 of these in series with a compression driver following a crossover and maitaining 8 ohms.
This is being considered for a Carvin RL210T cab, which is currently 4 ohms, 400 watts. I need to switch it to 8 ohms. Do the comp driver and crossover affect the impedence? If so, what should the impedence of the hf driver be?
The compression driver will affect the impedance, but the crossover won't. Basically, whatever you put on the low-freq output of the crossover is the impedance that the amplifier will see at frequencies below the crossover point; whatever you put on the high-freq output of the crossover is the impedance that the amplifier will see at frequencies above the crossover point. These two impedances can be different (but it's recommended that they not be). So, if you use 2 of the Eminence woofers in series, that will add up to 8 ohms, so the amp will have an 8 ohm load below the crossover point. If you then use an 8 ohm comp driver then there will be an 8 ohm load above the crossover point, which will make for an 8 ohm load at all frequencies, which is what you'll want. If, on the other hand, you use a 4 ohm comp driver then you'll still have the 8 ohm load from the woofers at low frequencies, but you'll now have a 4 ohm load at high frequencies. Doing that would cause all sorts of problems: the tweeter would get twice as much power as the woofer (so there'd be too much treble), you'd have to have crossovers rated for different impedances for the woofer and tweeter, and it wouldn't actually be a "8 ohm" speaker system because it would only be 8 ohms at low frequencies.So, you need an 8 ohm compression driver.
Answered by: eboyer
Date published: 2011-12-23
Can an SWR Baby Blue II 10" use this 4 Ohm speaker?
The speaker on my SWR Baby Blue II 10" recently blew. This 1-10 combo is rated 120 watts @ 8 Ohms. I'd like to be able to connect an old SWR Workingman's 10" extension cab to the BBII (I need to keep my equipment compact). Maybe the amp has enough power for both speakers, but I was thinking of changing both speakers to the BP102-4 for more power. At 4 Ohms the BBII goes to 160 watts. Is this workable - and wise? Thanks.
Asked by: TimC
If you are planning connecting an extension cab each woofer will have to be rated for 8 ohms in order to maintain a safe 4 ohm load to the amplifier. If you only plan on using the combo by itself this woofer will work fine.
Date published: 2013-11-04
I am considering replacing the speakers in a Hartke 210XL cab to stack on top of an eminence cb115 cab. Would two of the BP102-4 speakers (wired in series to get to 8ohm) work well in this setup, or would you suggest something else?
Asked by: gyver1
A pair of these would work very well in an application like that.
Date published: 2014-03-31
Customer projects that include: Eminence Legend BP102-4 10" Bass Guitar Driver 4 Ohm
