Eminence LAB15 15" Pro Audio Subwoofer Speaker
Brand:|Model: LAB15|Part # 290-575
The Lab15 is a high-power, high excursion 15" subwoofer driver for applications requiring very deep bass at pro sound levels.
$284.99
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-575
  • Extensive venting keeps the 3" voice coil cool with minimal power compression
  • 11.8 mm of excursion for moving a large volume of air
  • Kevlar reinforced treated paper cone with foam surround for natural response
  • Rigid 12 spoke cast aluminum frame can take the abuse of pro sound
The Lab15 is a high-power, high excursion 15" subwoofer driver for applications requiring very deep bass at pro sound levels. Features include a 3" voice coil wound on a double layer aluminum former, an epoxy-reinforced apex/neck joint, and a double-laminated spider. This speaker also features a vented motor, both under the spider and through the backplate. Recommended for medium to large sized vented cabinets or horn-loaded designs for PA, sound reinforcement, or dance club applications. The Lab 15 is also suitable for small sealed cabinets for automotive use.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance6 ohms
  • Frequency Response20 to 125 Hz
  • Sensitivity88.5 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight160 oz.
  • Resonant Frequency (Fs)28 Hz
  • DC Resistance (Re)4.90 ohms
  • Voice Coil Inductance (Le)3.23 mH
  • Mechanical Q (Qms)5.36
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)3.66 ft.³
  • Mechanical Compliance of Suspension (Cms)0.11 mm/N
  • BL Product (BL)26.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)308g
  • Maximum Linear Excursion (Xmax)11.80 mm
  • Surface Area of Cone (Sd)823.7 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.34"
  • Baffle Cutout Diameter14"
  • Depth7.75"
  • # Mounting Holes8
  • Sealed Volume0.69 ft.³
  • Sealed F368 Hz
  • Vented Volume1.79 ft.³
  • Vented F340 Hz
  • BrandEminence Speaker
  • ModelLAB15
  • Part Number290-575
  • UPC876358001729
    (4 Reviews)
  • Weight27.2 lbs.
View similar products to the Eminence LAB15 15" Pro Audio Subwoofer Speaker
