Bonus Item Incl.
290-575_ALT_0
290-575_ALT_1
Eminence LAB 15 15" Pro Audio Subwoofer Speaker
Brand:| Model: LAB 15
The Lab15 is a high-power, high excursion 15" subwoofer driver for applications requiring very deep bass at pro sound levels.
290-575
Weight: 27.2 lbs.
IN STOCK
$294.99
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
Part # 290-575
The Lab15 is a high-power, high excursion 15" subwoofer driver for applications requiring very deep bass at pro sound levels. Features include a 3" voice coil wound on a double layer aluminum former, an epoxy-reinforced apex/neck joint, and a double-laminated spider. This speaker also features a vented motor, both under the spider and through the backplate. Recommended for medium to large sized vented cabinets or horn-loaded designs for PA, sound reinforcement, or dance club applications. The Lab 15 is also suitable for small sealed cabinets for automotive use.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance6 ohms
  • Frequency Response20 to 125 Hz
  • Sensitivity88.5 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight160 oz.
  • Resonant Frequency (Fs)28 Hz
  • DC Resistance (Re)4.9 ohms
  • Voice Coil Inductance (Le)3.23 mH
  • Mechanical Q (Qms)5.36
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)3.7 ft.³
  • Mechanical Compliance of Suspension (Cms)0.11 mm/N
  • BL Product (BL)26.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)308g
  • Maximum Linear Excursion (Xmax)11.8 mm
  • Surface Area of Cone (Sd)823.7 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.34"
  • Baffle Cutout Diameter14"
  • Depth7.75"
  • # Mounting Holes8
  • Sealed Volume0.69 ft.³
  • Sealed F368 Hz
  • Vented Volume1.79 ft.³
  • Vented F340 Hz
  • BrandEminence Speaker
  • ModelLAB 15
  • Part Number290-575
  • UPC876358001729
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (3 Reviews)
  • Weight27.2 lbs.
View similar products to the Eminence LAB 15 15" Pro Audio Subwoofer Speaker
in the Woofers, Subwoofers & Midrange Speakers product category.
Eminence LAB 15 15" Pro Audio Subwoofer Speaker is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Great buyCouldn't be happier! This sub is a beast!!!Great quality, the sound level is stellar! Amazed by the sound this sub puts out!
Date published: 2013-08-19
Rated 5 out of 5 by from Does the job wellI built the picture sub according to the Eminence Med Size Vented Club Sub spec. It was built to supplement the warm up music for a small private schools basketball team. It does a great job at adding a whole new dimension to the atmosphere of the gym. Keep in mind that this is a 6 ohm speaker and you won't get the 4 ohm rated watts that is on a lot of amplifiers. I first tried the Bash 500 and it made my house shake but wasn't enough for the gym. I ended up using the Crown XLS1000 Drive Core which should give it around 900 watts at 6 ohms and it worked out great for our application.
Date published: 2013-04-11
Rated 5 out of 5 by from open baffle setupcurrently use these in a legacy whisper design and they haveeasily surpassed my expectations.4 in each speaker and yes open baffle. power is by yamaha p7000 (2) so the 2 front get1 channel,rear 2 get 1 channel etc. set up to 120hz.they give a great clean,tight punch.if i want more,i mean much more punch i just close the door on room and then it acts as a sealed chamber and easily will shake your vision,no joke.will easily overpower my jbl518 sub.these subs are used in zu dominance as downfiring sub btw @ 40k.rest of my diy speaker,which is a box with 12" passive on back and the front has (4) 6.5 midwoofers,same ones as Klipsch kl-650 set at 625hz, one 3 in. tang band dome mid, one tang band ribbon. have probably 4k in whole build.finish is blackoak. its one heck of a sub,practically indestructable.
Date published: 2012-03-10
Being that this is rated @ 6ohms, what impedance should the power amp driving it be?
Asked by: smitty222
Your amplifier needs to be rated to safely drive at least a 6 ohm load, 4 would be safer.
Date published: 2012-10-30
Has anybody a plan to bild a small cube box for eminence lab 15 pro subwoofer?
Asked by: woofy
Eminence provides suggested enclosure designs for all their current speakers on the eminence.com website. For this particular speaker, use the following link:http://www.eminence.com/pdf/LAB_15_cab.pdfYou could also use BassBox 6 Pro, referenced below.
Answered by: RussR
Date published: 2013-08-07
Customer projects that include: Eminence LAB 15 15" Pro Audio Subwoofer Speaker
