Eminence Kilomax Pro-18A 18" Cast Frame Driver
Brand:|Model: Kilomax Pro-18A|Part # 290-434
Eminence's Kilomax Pro-18A 18" speaker is designed to provide excellent performance in professional audio subwoofer and woofer applications in larger vented or sealed enclosures.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
$259.99
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
Part # 290-434
  • Kapton coil former
  • Copper voice coil
  • Extended core with Core Periphery Ventilation
  • Die-cast aluminum basket
  • Aluminum heatsink
  • Paper cone with cloth cone edge
  • Porous cloth top spider
Eminence's Kilomax Pro-18A 18" speaker is designed to provide excellent performance in professional audio subwoofer and woofer applications in larger vented or sealed enclosures. The Kilomax Pro-18A's unique axially-located heat sink removes excessive thermal buildup from the critical voice coil area, which contributes to the driver's 1,250 watts RMS power handling capacity. Not recommended for horn loading or scoops. Made in the USA. 7-year manufacturer's warranty!
  • Nominal Diameter18"
  • Power Handling (RMS)1250 Watts
  • Power Handling (max)2500 Watts
  • Impedance8 ohms
  • Frequency Response33 to 300 Hz
  • Sensitivity95.8 dB 1W/1m
  • Voice Coil Diameter4"
  • Magnet Weight109 oz.
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)5.07 ohms
  • Voice Coil Inductance (Le)1.59 mH
  • Mechanical Q (Qms)10.15
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)11.71 ft.³
  • Mechanical Compliance of Suspension (Cms)0.18 mm/N
  • BL Product (BL)17.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)143g
  • Maximum Linear Excursion (Xmax)10 mm
  • Surface Area of Cone (Sd)1159 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter18"
  • Baffle Cutout Diameter16.56"
  • Depth8.15"
  • # Mounting Holes8
  • Sealed Volume5.51 ft.³
  • Sealed F351 Hz
  • Vented Volume16 ft.³
  • Vented F326 Hz
  • BrandEminence Speaker
  • ModelKilomax Pro-18A
  • Part Number290-434
  • UPC876358000517
    (11 Reviews)
  • Weight30.25 lbs.
View similar products to the Eminence Kilomax Pro-18A 18" Cast Frame Driver
Eminence Kilomax Pro-18A 18" Cast Frame Driver is rated 4.5455 out of 5 by 11.
Rated 5 out of 5 by from Best sub. for the priceI buy this a month ago and could not wait to install it because I have three already. when I had a monster sound last year I used twelve of these things for my bass line, They are awesome.
Date published: 2015-11-07
Rated 5 out of 5 by from killomax pro 18-AI have 2 cerwin vega El 36c sud rated at 500 watts Rms and replace it withThe killomax pro 18-A and they sound great at 1250 watts Rms very happy with my purchase you cant go wrong with these .
Date published: 2014-02-03
Rated 5 out of 5 by from Use a smaller boxI highly recommend using this sub in a really small enclosure. 5 cu. ft tuned to 40-45hz with no or minimal fill puts the mechanical power handling right up there with the electrical power handling. The smaller box minimizes the cone displacement within the xmax all the way up to 1250W. People have problems with this sub using it in any bigger box because say in a 10 cu. ft enclosure you're already out of travel at just 500 watts below 60hz. So trying to give it a lot of power in a big low tuned box is going to make it easy to rip the cone from the suspension. It sounds great in this enclosure with a ton of punch around 63hz major kick drum power and plenty of bang and rumble at 40-50. Use a 24db/octave high pass at 35-40hz
Date published: 2010-07-12
Rated 4 out of 5 by from pretty killer, has limitsI'm going to start by establishing a baseline. My system utilizes 4 McCauley 6174's. Simply stated, the Kilomax's can't touch them. I had an idiot of a sound guy run the board for a band and smoked a pair of the 6174's. Replacement baskets would have taken 4 weeks to come in and I had shows lined up. I did some box modeling with the TSP of several drivers and the kilomax's came the closest to the 6174's. Ordered them and 3 days later they were here. I really dig them. They're well made. The heatsink on the front is a great idea (but not for my boxes cause they use an inverted driver alignment). They sound really good. Very solid in the 45-65 range. Good transient response. Now the problem. The 6174's have an incredible suspension. 15.6mm X-max, over 2" in the nonlinear travel zone. They will not bottom out. I don't put hi-pass filters on them. They don't need it. They actually run COOLER WITHOUT it. The Kilomax however isn't built to do this. They MUST have a hi-pass filter. The power handling is great when you set the filters properly. I didn't have any. The cone slammed so far in and out that it separated from the spider. The voice coil is in good shape, and there are no signs of overheating. Only mechanical damage. No electrical overpowering, only mechanical overpowering. I like these drivers, and for the price they're a good deal, but know their limits. Use hi-pass filters and you'll be very satisfied.
Date published: 2010-05-03
Rated 4 out of 5 by from use the cab design on the WebSiteI built 4 cabs using the Eminence site's size and port recommendations. A really good design and the box is very powerful and punchy. Not only those 2 attributes, but the box/driver combo is very musical and the notes are clear and undistorted. A hard combination in the bass world (you can easily tell the B string from the E string on a bass guitar at power) as well as having real bass clarity in sound reinforcement. The critical thing about this driver is the motor is SO powerful it can exceed the suspension's ability to control the cone if it's not used correctly in the right tuning. Get it in their box and Hi-Pass it STEEPLY at 40hz. For really loud use, HP it at 50hz. Thermally this driver is great, it can dissipate heat as fast as it makes it with normal use. But if you're clipping the amps, bring in more boxes and more amps. There is nothing to gain using the voice coil as an "Easy Bake" oven. It will not get any louder. Just treat the suspension with some common sense and think about what this driver is going thru. Any driver that can do a 9mm Xmax has some serious acceleration/deceleration going on.
Date published: 2010-03-01
Rated 4 out of 5 by from SBS SYSTEMSBYSHORTY.COM REVIEW OF kilomaxSOLID BUILT DRIVER, VOICED TO SOUND GOOD WITH ANYTHING YOU PLAY ON THEM. I HAVE BEEN IN BUISINESS OF BUILDING CUSTOM SOUND SYSTEMS THRU MY SOUND COMPANY SBS SYSTEMSBYSHORTY.COM I HAVE BEEN A FAN OF THE EMINENCE PRODUCT FOR MANY YEARS AS WELL AS USED THEM FOR MANY YEARS. I HAVE SOME SYSTEMS I INSTALLED OVER 10 YEARS AGO THAT RUN 7 DAYS A WEEK, AND THEY HAVE NEVER BLOWN WITH THE OMEGA SERIES 15S AND 16S, THE KILOMAX IS UNSTOPABLE, JUS A WORK HORSE OF A DRIVER. IT JUST DOES EVERYTHING RTThe way they have designed the coil venting out the front of the driver is genious, less chance of thermal compresion in the driver because the heat does not get trapped in the box. Great product
Date published: 2009-11-26
  • 2016-02-10T06:39CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_290-434, PRD, sort_mostRecent
Can these be front mounted?
Asked by: labdork
Yes, these can be front or rear mounted.
Date published: 2015-12-03
Xmax is claimed to be 10mm. I have seen in the past that some manufacturers seem to claim Xmax as peak-to-peak. Is the stated 10mm peak-to-peak or one direction (20mm peak-to-peak)? Very important in my application, sub-30hz EQ'ed subwoofer.
Asked by: silverhairbp
Eminence rates their Xmax as one-way.
Date published: 2015-09-08
Looking to go with a 4.5-5. Cuft looking for port size and depth to be toned at 38-40hz or will this box be to small.  Thank you Jerry
Asked by: FTL music
Unfortunately that box is far too small for this woofer. If you need a volume around 5 cubic feet, I would recommend our Dayton PA465S-8 instead. In 5 cubic feet total with a slot port that is 20.5"H x 1.5"W x 15"D you will have a tuning frequency of 32 Hz.
Date published: 2015-06-01
Rectangular port depth in a 5.5 cubic foot box
What would the port depth be for a 2" tall by 20" wide port be for this driver in a 5.5 cubic foot box for 45Hz? My box is going to have an internal dimension of 26" tall by 20" wide by 18" deep. I plan to line the inside with the 3/4" dampening foam sold by PE as well, and there will be another small loss of volume from the handles, and pole mount. I plan to place the port at the bottom front of the cabinet. Power will be provided by a Crown XLS2000.
Asked by: Bake986
A 2" H x 20" W slot port in a 5.5 cu ft box tuned to 45Hz comes to ~5" long.Be warned though in that size box tuned to 45hz you will have a 4db peak at 75Hz, F3 will be 55Hz, and F10 is 40Hz.
Answered by: mtg90
  • 2016-02-10T07:39CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_290-434, PRD, sort_recentQuestionsFirst
