Eminence Kappalite 3010MB 10" High Power Neo Midbass/Midrange Speaker
Brand:|Model: Kappalite 3010MB|Part # 290-667
Eminence' Kappalite 3010MB is an all-purpose 10" professional audio speaker. 5 mm of Xmax and high 98 dB sensitivity allow it to be used as a woofer in 2-way floor monitors, while the extremely smooth midrange response makes it a natural choice as a midrange/midbass in 3-way speakers.
$179.99
Part # 290-667
  • High sensitivity design
  • Smooth midrange response
  • Able to be used as a small format pro woofer
  • Lightweight design with neo motor and truncated cast aluminum frame
  • Vented pole piece
The Kappalite 3010MB 10" midbass/midrange driver from Eminence has it all! High sensitivity, a high-energy neodymium motor, extremely smooth response from 85 Hz to 3 kHz, and it clocks in at under 8 pounds. You can use the Kappalite 3010MB as a small format woofer in vented stage and studio 2-way monitors or as a high fidelity midrange in professional live sound 3-way speaker cabinets.
For reduced power compression, the pole piece is vented and the neodymium magnet is attached to extensive aluminum heat sinks built onto the die-cast frame. The edge-wound 3" copper voice coil increases power handling without sacrificing sensitivity. A durable treated paper cone can take years of abuse. For close driver-to-driver spacing, the frame is truncated. Proudly made in the U.S.A.
Refer to the Manuals/Resources section for recommended cabinet designs from Eminence.
  • Nominal Diameter10"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response85 to 3,600 Hz
  • Sensitivity98.6 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight11 oz.
  • Resonant Frequency (Fs)51 Hz
  • DC Resistance (Re)5.01 ohms
  • Voice Coil Inductance (Le)0.68 mH
  • Mechanical Q (Qms)6.83
  • Electromagnetic Q (Qes)0.21
  • Total Q (Qts)0.20
  • Compliance Equivalent Volume (Vas)1.84 ft.³
  • Mechanical Compliance of Suspension (Cms)0.28 mm/N
  • BL Product (BL)16.51 Tm
  • Diaphragm Mass Inc. Airload (Mms)36g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)366.1 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter11.18"
  • Baffle Cutout Diameter9.12"
  • Depth4.61"
  • Sealed Volume0.12 ft.³
  • Sealed F3199 Hz
  • Vented Volume0.22 ft.³
  • Vented F3133 Hz
  • BrandEminence Speaker
  • ModelKappalite 3010MB
  • Part Number290-667
  • UPC876358002085
  • Weight8 lbs.
View similar products to the Eminence Kappalite 3010MB 10" High Power Neo Midbass/Midrange Speaker
