Eminence Kappalite 3010LF 10" High Power Neo Subwoofer Speaker
Brand:|Model: Kappalite 3010LF|Part # 290-665
Eminence designed the Kappalite 3010LF to take advantage of the size and weight advantages of a neodymium motor. The end result is a subwoofer that is truly lightweight and portable without sacrificing bass performance.
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-665
  • Amazingly small and light professional subwoofer driver
  • Neodymium-powered motor design for high BL product
  • Die-cast aluminum frame
  • High sensitivity and vented pole piece for reduced power compression
  • Low Qts for use in vented and horn-loaded enclosures
  • Made in the U.S.A.
The Kappalite 3010LF from Eminence is a new direction in professional subwoofer driver design. Eminence chose a neodymium motor, known for maximum BL product (magnet energy) while remaining lightweight, a truncated die-cast aluminum basket for rigidity, vented pole piece (for reduced power compression), and a treated paper cone with cloth accordion surround.
Eminence optimized the Kappalite 3010LF for use in vented and horn-loaded enclosures, which is evident in the ultra-low Qts figure of 0.27. Over a half inch of total excursion is available and an Fs of 38 Hz allows this speaker to play relatively low for its size, while remaining sensitive (92.7 dB 1W/1m). Proudly made in the U.S.A.
Refer to the Manuals/Resources section for recommended cabinet designs from Eminence.
  • Nominal Diameter10"
  • Power Handling (RMS)450 Watts
  • Power Handling (max)900 Watts
  • Impedance8 ohms
  • Frequency Response42 to 1,600 Hz
  • Sensitivity92.7 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight11 oz.
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)7.20 ohms
  • Voice Coil Inductance (Le)1.13 mH
  • Mechanical Q (Qms)11.75
  • Electromagnetic Q (Qes)0.28
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)2.20 ft.³
  • Mechanical Compliance of Suspension (Cms)0.35 mm/N
  • BL Product (BL)17.45 Tm
  • Diaphragm Mass Inc. Airload (Mms)49g
  • Maximum Linear Excursion (Xmax)8.52 mm
  • Surface Area of Cone (Sd)358.4 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter11.18"
  • Baffle Cutout Diameter9.12"
  • Depth5"
  • Sealed Volume0.28 ft.³
  • Sealed F3113 Hz
  • Vented Volume0.55 ft.³
  • Vented F372 Hz
  • BrandEminence Speaker
  • ModelKappalite 3010LF
  • Part Number290-665
  • UPC876358002092
  • Weight9 lbs.
B&C 15HPL76 15" Neodymium Woofer
Part #  294-682
B&C 15PS100 15" Woofer
Part #  294-673
View similar products to the Eminence Kappalite 3010LF 10" High Power Neo Subwoofer Speaker
