Eminence Kappalite 3010HO 10" High Output Neodymium Midrange Speaker
Brand:|Model: Kappalite 3010HO|Part # 290-664
Eminence designed the Kappalite 3010HO to take advantage of the size and weight advantages of a neodymium motor. The end result is a midrange that is truly lightweight and portable without sacrificing performance.
OUT OF STOCK
Awaiting Updated Due Date
$179.99
Eminence Baseball Cap
Qty: 1Part # 520-300
List Price:$19.99
*Domestic US orders only
Part # 290-664
  • Amazingly small and light professional midrange driver
  • Neodymium-powered motor design for high BL product
  • Die-cast aluminum frame
  • High sensitivity and vented pole piece for reduced power compression
  • Low Qts for use in small sealed or vented enclosures
  • Made in the U.S.A.
The Kappalite 3010HO from Eminence is a new direction in professional midrange driver design. Eminence chose a neodymium motor, known for maximum BL product (magnet energy) while remaining lightweight, a truncated die-cast aluminum basket for rigidity, the vented pole piece (for reduced power compression), and a treated paper cone with cloth accordion surround.
Eminence optimized the Kappalite 3010HO for use in small sealed and vented enclosures (for use as a woofer in stage monitors), which is evident in the ultra-low Qts figure of 0.26. Over 4 mm of total excursion is available and an Fs of 61 Hz allows this speaker to play relatively low while remaining sensitive (99.9 dB 1W/1m). All of this and a flat frequency response from 450 to 4,000 Hz. Proudly made in the U.S.A.
Refer to the Manuals/Resources section for recommended cabinet designs from Eminence.
  • Nominal Diameter10"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity99.9 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight11 oz.
  • Resonant Frequency (Fs)61 Hz
  • DC Resistance (Re)5.46 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)9.93
  • Electromagnetic Q (Qes)0.27
  • Total Q (Qts)0.26
  • Compliance Equivalent Volume (Vas)1.31 ft.³
  • Mechanical Compliance of Suspension (Cms)0.20 mm/N
  • BL Product (BL)16.27 Tm
  • Diaphragm Mass Inc. Airload (Mms)34g
  • Maximum Linear Excursion (Xmax)4.43 mm
  • Surface Area of Cone (Sd)366.1 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter11.18"
  • Baffle Cutout Diameter9.12"
  • Depth4.61"
  • Bolt Circle Diameter10.49"
  • # Mounting Holes4
  • Sealed Volume0.15 ft.³
  • Sealed F3186 Hz
  • Vented Volume0.3 ft.³
  • Vented F3120 Hz
  • BrandEminence Speaker
  • ModelKappalite 3010HO
  • Part Number290-664
  • UPC876358002078
  • Weight8.05 lbs.
Pyle PBW10S 10" Midbass
Part #  292-2528
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
RCF L15P540 15" Woofer Speaker
Part #  294-860
View similar products to the Eminence Kappalite 3010HO 10" High Output Neodymium Midrange Speaker
