Eminence Kappa Pro-12A 12" Cast Frame Driver
Brand:|Model: Kappa Pro-12A
The Eminence Kappa Pro-12A 12" speaker is recommended for professional audio as a sealed or vented midbass, or in a vented bass enclosure incorporating a high-pass filter.
Part # 290-424
  • Kapton coil former
  • Polyamide-imide coated copper voice coil
  • Ferrite magnet
  • Vented and extended pole piece
  • Die-cast aluminum basket
  • Paper cone with cloth accordian surround
  • Solid composition paper dust cap
The Eminence Kappa Pro-12A 12" speaker is recommended for professional audio as a sealed or vented midbass, or in a vented bass enclosure incorporating a high-pass filter. Also works great in horn-loaded designs, thanks to its high motor strength and excellent EBR (Equivalent Bandwidth Ratio). Made in the USA. 7-year manufacturer's warranty!
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response57 to 2,800 Hz
  • Sensitivity97.1 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight80 oz.
  • Resonant Frequency (Fs)37 Hz
  • DC Resistance (Re)5.46 ohms
  • Voice Coil Inductance (Le)1.22 mH
  • Mechanical Q (Qms)6.93
  • Electromagnetic Q (Qes)0.25
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)4.27 ft.³
  • Mechanical Compliance of Suspension (Cms)0.32 mm/N
  • BL Product (BL)17.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)59g
  • Maximum Linear Excursion (Xmax)4.8 mm
  • Surface Area of Cone (Sd)519.5 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.38"
  • Baffle Cutout Diameter11.07"
  • Depth6.22"
  • # Mounting Holes8
  • Sealed Volume0.34 ft.³
  • Sealed F3132 Hz
  • Vented Volume0.75 ft.³
  • Vented F385 Hz
  • BrandEminence Speaker
  • ModelKappa Pro-12A
  • Part Number290-424
  • UPC876358000364
    (2 Reviews)
  • Weight17.71 lbs.
View similar products to the Eminence Kappa Pro-12A 12" Cast Frame Driver
Eminence Kappa Pro-12A 12" Cast Frame Driver is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from The finest loudspeaker in it's category...I've built dozens of cabinets for front-of-house and stage monitor applications using the Kappa Pro Series over the past seven years with stellar success. Frequency response, fidelity, sensitivity, power-handling, reliability are all hallmarks of this line. Additional high quality features like high capacity binding posts and thick gaskets for front or rear cabinet mounting make this series my first choice. Eminence continues to be an industry leader providing loudspeakers and drivers for numerous major manufacturers and has branched out ever further with excellent choices in their lightweight neodimium speakers. Dozens of speakers to choose from in nearly every category and Made In The United States at very fair prices with excellent distribution. Parts Express is also one of the best at what they do!
Date published: 2009-07-18
Rated 4 out of 5 by from Best for specific applicationsMy main application was a horn loaded mid-bass from 80-300 Hz that was designed around this specific driver. Highest EBP in its price class, period. It performed as per the models - very, very, very LOUD - able to keep up with labhorns. I've played with this driver in small vented boxes, and it does well in about 1 cubic foot. Only downside is that it's top end isn't as nice as the Delta series, so it's more at home in a 3 way than a 2 way. Unless you're using a 2" on top. Teamed up with a couple of 6" and a 1" horn/driver, the box is still small enough - and cheap enough - to be thinking "line array".
Date published: 2007-07-11
  • 2015-10-13T06:55CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_290-424, PRD, sort_mostRecent
any idea where finds plans for horn loading kappa pro12 .....
Asked by: mh1234
We do not have any specific plans for this driver, but you may check out our Tech Talk forum for ideas, or possibly contact Eminence directly to see if they might have a source for this.
Date published: 2014-12-05
  • 2015-10-13T07:47CST
  • loc_en_US, sid_290-424, PRD, sort_recentQuestionsFirst
Get Sales Flyer
